Author Topic: more power 1.6td (UPPING THE BOOST)  (Read 18751 times)
Reply #15May 28, 2004, 10:26:02 am
Dr. Diesel
  • Authorized Vendor
  • 1341
« Reply #15 on: May 28, 2004, 10:26:02 am »
Stan, go ahead and plug the outlet hose for the BOV. I found a 1" long section of broom handle jammed inside and clamped works great. I think you'll be suprised at how high the boost goes.  Then you'll be really wanting a good boost controller.  I've made my own, and it's worked great for 6 months now, and is totally adjustable. I'll make a detailed post on how to do it for those interested, soon.
Reply #16May 28, 2004, 10:32:09 am
VWRacer
  • 649
« Reply #16 on: May 28, 2004, 10:32:09 am »
I plugged the BOV (per the Bentley procedure) and did another test run, but am still making a maximum of 12 psi boost at full "throttle" in 3rd gear. Could the BOV be releasing the air somewhere other than out that tube?
Stan
C-Sports Racer
Reply #17May 30, 2004, 10:16:34 am
andy2
« Reply #17 on: May 30, 2004, 10:16:34 am »
:) VW Racer as long as you plugged the BOV off , 12.5-13 psi is all that k24 is going to give you with NO pump mods (more fuel).It also only takes a small increase in fuel to get higher boost with the non wastegated setup.
Reply #18May 30, 2004, 12:26:06 pm
VWRacer
  • 649
« Reply #18 on: May 30, 2004, 12:26:06 pm »
Thanks for the info, Andy. I thought there might be something wrong with my engine.
I need to open up the exhaust and do some more research before trying to add fuel. In fact, I really don't know how to add fuel. My Bentley's identifies the rod that sets max RPM (5050-5150), but doesn't get into tuning it.
I think there was a link recently to a page where someone identifies the major go-fast parts of the pump, but that pump looks quite different to mine... :?
In any case, I will be sending it to Giles after I pull the engine. :idea:
Stan
C-Sports Racer
