Author Topic: Which Turbo is Better  (Read 23713 times)
Reply #15May 27, 2004, 08:55:41 pm
DieselsRcool
  • 152
« Reply #15 on: May 27, 2004, 08:55:41 pm »
QuickTD
I'm there, all but the intercooler. They don't do much at 2mph. :(
Reply #16May 27, 2004, 10:04:12 pm
dieselpower
  • 177
« Reply #16 on: May 27, 2004, 10:04:12 pm »
will a TDI exhaust manifold bolt up directly to a 1.6TD head. because arent the TDI variable vane turbos integrated into the ex. manifold?
84 rabbit 1.6TD
because real cars don't have sparkplugs
Reply #17May 27, 2004, 10:56:26 pm
DVST8R
  • 535
« Reply #17 on: May 27, 2004, 10:56:26 pm »
Well I think that the k03 in sequence with a k24/k26hybrid, or straight k26. Sounds about right  :twisted:  I am looking for a holset hy35w with the 9cm housing off a 01' dodge with an auto. For a scavenger for my 1.6TD garrett  :shock: , I think that should probably give me enough turbo to compress a giles pump 8)
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #18May 28, 2004, 09:28:17 am
fspGTD
  • 1529
    • http://home.comcast.net/~vwgtd
« Reply #18 on: May 28, 2004, 09:28:17 am »
Quote from: "dieselpower"
There was a post on the old forum on this, very informative - I found it here:
http://www.hostboard.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=4037&t=171
Answer is that yes, looks like the variable-vane turbo would fit on an A1.  Looks like the main trick would be adapting the VNT controller to work on a non-ECU (mechanically controled) motor.
Jake Russell
Dieselicious Turbocharger Upgrade/Rebuild Kits
