Author Topic: help plz,plz 1.9 TD pump wires????  (Read 7964 times)
January 23, 2005, 11:13:29 am
daz 585
  • 4
« on: January 23, 2005, 11:13:29 am »
hi their guys, would anyone have a clue :?:  as to what the 2 wires i have on the back of my injector pump between the injector pipes do, the engine is fitted into my mk1 caddy the engine was taken out by a friend around x,mas :cry: ,now i have come to put it back in i carnt seem to find out where these 2 wires go or what they are for, has anyone got a clue as to where they wire up and what they are suposed to do, if you look where the injector pipes bolt up to the pump in the middle of the pipes their is two wires coming out, i have looked at another 1.9 td engine i have but this pump is diffrent by having a bolt their :? ,plz anyone help me,thanks daz :oops:  :oops: sorry dont really know what model the engine is apart from it been a 1.9 td, non intercooler
Reply #1January 24, 2005, 07:57:38 am
asau
« Reply #1 on: January 24, 2005, 07:57:38 am »
hook them both together and then to 12v ignition. the pump wire closer to the flywheel is for the fuel feed. the pump wire closer to the crank is suppose to be for better fuel economy less power.
Reply #2January 25, 2005, 10:39:59 am
daz 585
  • 4
« Reply #2 on: January 25, 2005, 10:39:59 am »
asau, how do you mean the pump wire closest to the flywheel?? and wire closest to the crank??? sorry buddy i dont follow you the two wires what are coming from the back of the fuel pump are the same lenght???, could you explain in what you mean if we are talking about the same 2 wires,, if you look at the end of the fuel pump where all the injector pipes bolt on to the fuel pump, in the middle of the pipes,are 2 wires coming from the middle of the injector pump,, the colours of the 2 wires i think are black and green, any clues or still hook them both up to the 12v ingnition feed?? thanks for your advise so far daz
Reply #3January 25, 2005, 07:17:04 pm
MK3 GTD
  • 48
« Reply #3 on: January 25, 2005, 07:17:04 pm »
He is referring to the stop solenoid and timing advance wires, which i dont think is what you meant.
Are the two wires you mentioned going into something that threads into the pump head like a sensor?
I have never seen a vw diesel pump that had wires there, its usually just a plug bolt.
That hole is used to thread in a dial indicator to time the injection based on plunger position inside the pump.
1996 Golf 1.9TD
1984 Rabbit 1.6TD
1987 Jetta Coupe 1.6D
Reply #4January 26, 2005, 06:29:40 am
asau
« Reply #4 on: January 26, 2005, 06:29:40 am »
in the pic on the injection pump there are 2 wires, one with a hard white plastic covering the injection pump, and another with black. the white one is the fuel cut off switch the black one is the economy one.
sorry about the pic the best i have that is already online
Reply #5January 26, 2005, 11:18:47 am
daz 585
  • 4
« Reply #5 on: January 26, 2005, 11:18:47 am »
the photo is a completley diffrent pump buddy to mine, mk3 has hit the nail on the head with the wires, but its def not those in the photo you have shown, its driving me mad is this one lol, any ideas what they are for what mk3 is talking about as they sound the same, daz
Reply #6January 27, 2005, 08:44:04 am
asau
« Reply #6 on: January 27, 2005, 08:44:04 am »
is your 1.9 a tdi?
Reply #7January 27, 2005, 10:11:15 am
daz 585
  • 4
« Reply #7 on: January 27, 2005, 10:11:15 am »
asua, no buddy its just the 1.9 td,
Reply #8January 27, 2005, 07:40:43 pm
MK3 GTD
  • 48
« Reply #8 on: January 27, 2005, 07:40:43 pm »
any chance of getting a picture of the pump? are you sure its a 1.9TD pump? the only pumps ive seen with wires there were on 6.5L chevy TDs which are electronically controlled.
1996 Golf 1.9TD
1984 Rabbit 1.6TD
