General Information
Troubleshooting
Strange knocking sound
Topic: Strange knocking sound (Read 4487 times)
June 30, 2007, 01:41:56 pm
brumble
Newbie
June 30, 2007, 01:41:56 pm »
Hi to everyone
This is the first time i post here so please bear over with me
I have recently changed the timing belt and valve seals on my 1.6 d Golf II, at the same time i got hold of a turbo kit for my n/a motor and of course i mounted this
The engine starts up and runs fine even when revving it, but when driving and stepping on the accelerator the engine gives off a strange metallic knocking sound, this sound wears off when the desired speed is reached. I am currently running 0,6 Bar boost. could anyone please help me find out what this is?
Any help is greatly appreciated.
Best regards
Brumble
July 01, 2007, 07:04:21 am
July 01, 2007, 07:04:21 am »
i don't know if this applies, but my transmission makes some weird noises before it hits 2k rpm or so...
July 01, 2007, 08:12:33 am
brumble
Newbie
July 01, 2007, 08:12:33 am »
Hi,
Thanks for the answer, but i seriosly doubt this sound is coming from the tranny. The reason being that I have been using this tranny for a long time, and I have never had any issues with it. Any other ideas what it might be?
July 01, 2007, 05:38:56 pm
July 01, 2007, 05:38:56 pm »
try double checking your timing. did you use the timing instructions from the Bentley? hopefully it isn't a valve just barely smacking a piston :shock:
mine also made a weird noise like that... but it goes away when warm and since i put in 5w50 oil. almost sounds like a valve is sticking... she still runs good though!
July 02, 2007, 07:32:43 pm
bevboyy
July 02, 2007, 07:32:43 pm »
hydraulic or solid lifter head? Could be a sticky lifter.
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
July 03, 2007, 08:38:49 am
brumble
Newbie
July 03, 2007, 08:38:49 am »
Hi.
Thanks for your answers. Have just double checked my timing and it was ok
My engine has the letters CR stamped into the block, somewhere on the web i found this to be a solid lifter. How would I go about to check the lifters?
July 03, 2007, 08:42:46 am
July 03, 2007, 08:42:46 am »
you need a feeler gauge to measure the clearances, then buy shims and voila. a bentley manual at this stage is invaluable.
General Information
Troubleshooting
