Oil pan options?
Topic: Oil pan options? (Read 3149 times)
May 20, 2007, 11:42:13 am
westcoaster
Oil pan options?
May 20, 2007, 11:42:13 am »
So, What are my options for changing my oil pan on a 87? 1.6TD? (if there are any options...)
I have a motor out of a front wheel drive car swapped into my rear wheel drive samurai. The bung on the oil pan points right at the front pumpkin and there is about a 1/2 litre of oil left in the pan when doing a change (tilt and tip) I am looking for a pan with a bung at the flywheel end. (rear sump) If there is such an animal please let me know year, model, and if your really good, a part number on the oil pump if that needs to be changed....
Thanks,
'87 suzuki samurai with a 1.9 AAZ TD transplant
May 25, 2007, 04:35:25 am
somolovitch3
Oil pan options?
May 25, 2007, 04:35:25 am »
:lol: Have you looked at the HELP section of your local Auto Parts Super Store? They just might have a "Fix-It" fitting to replace a stripped oil bung.
Drill new oil drain hole where you want it, and install "Fix-It" part. No? :twisted:
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
May 25, 2007, 06:55:27 am
Darth Garry
Oil pan options?
May 25, 2007, 06:55:27 am »
You should have no trouble dropping the pan and replacing the bung. Any fab shop could do it, or if you can weld, even better.
Garry
All for one, and one for Awesomeness!
May 25, 2007, 09:38:11 pm
westcoaster
Oil pan options?
May 25, 2007, 09:38:11 pm »
Thanks for the replies,
I figured it was probably easiest to simply bore another hole and weld a bung at the lowest part of the pan. Since I have to tear the engine down anyway I figured I would ask if there are any other pan options available.
May 25, 2007, 11:03:31 pm
westcoaster
Oil pan options?
May 25, 2007, 11:03:31 pm »
Hmmm... The pan is different on the north south engines... I may need to reprase my question slightly different....
What model cars did VW make with a '87 1.6TD that were north/south (rear wheel drive) cars that were available in Canada? (I want to try and source the parts locally first)
I really don't know enough of the VW lineup to even start searching without a hint.
May 26, 2007, 12:02:50 am
westcoaster
Oil pan options?
May 26, 2007, 12:02:50 am »
Quote from: libbybapa
It has a large section to the rear that is quite skinny to clear the cross member.
Andrew
Humph!, well, that's no good.... I need it to be skinny at the front to clear the axel housing. :lol:
Thanks for the models, I'll search around now and see what I can find on those pans.
Any idea if the oil pump is different?
May 26, 2007, 12:10:28 am
westcoaster
Oil pan options?
May 26, 2007, 12:10:28 am »
http://replacement.autopartswarehouse.com/parts/autopartswarehouse/wizard.jsp?year=1987&make=VW&model=FOX--001&part=Oil%20Pan&dp=false
I see what your talking about being skinny....
I really could do with that indent on the other end of the pan....
Oil pan options?
