Author Topic: WTB AAZ std bore piston or two, good used ok  (Read 4633 times)
May 08, 2007, 05:49:37 pm
bigblockchev
  • 271
« on: May 08, 2007, 05:49:37 pm »
I have one really bad piston and another that would be nice to replace. Has anyone done a rebore & have their old slugs sitting gathering dust i could put them to use and a few bux in you pocket. Thanks all Dan
it's always something simple
one test is worth a thousand guesses
95 Chev Suburban 6.5 w performance mods
91 Mercedes 300D 603.960 6cyl 3L
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
5.5 years and counting on B100
Reply #1May 12, 2007, 06:55:24 am
dirtydiesel
  • 35
« Reply #1 on: May 12, 2007, 06:55:24 am »
i have all 4 pistons. good shape bored engine O\S don't need anymore
Reply #2May 12, 2007, 08:24:05 pm
bigblockchev
  • 271
AAZ pistons
« Reply #2 on: May 12, 2007, 08:24:05 pm »
I Pm'd you. I'm interested in the set My email is [email protected] thanks Dan Minchin
2000 Jetta TDI
Reply #3May 13, 2007, 06:20:51 am
dirtydiesel
  • 35
« Reply #3 on: May 13, 2007, 06:20:51 am »
will do Dan gimme a week ok
will email you
Reply #4May 15, 2007, 07:46:15 pm
bigblockchev
  • 271
Scary stuff oil pressure loss
« Reply #4 on: May 15, 2007, 07:46:15 pm »
I see that you are having your own scary times with oil pressure loss. I had my oil light come on last year but I ended up getting a new oil pump. Also had a bit of a discussion with a knowledgeable fellow about replacing worn intermediate shaft bearings , a known  issue with high mileage engines which mine is. Good luck Dan
2000 Jetta TDI
Reply #5May 24, 2007, 05:38:27 pm
dirtydiesel
  • 35
« Reply #5 on: May 24, 2007, 05:38:27 pm »
hey the oil pressure problem was a water pump bolt. It had backed out of the housing and jammed the inter shaft. i was very lucky.
