Author Topic: M-TDI Pump *UPDATED 1/7*  (Read 9589 times)
Reply #15June 15, 2007, 04:31:32 pm
orangea2vr6
  • 17
« Reply #15 on: June 15, 2007, 04:31:32 pm »
Just recieved my parts everything was great just wanted to give you a bump.
Reply #16June 16, 2007, 12:26:27 am
the4ork
  • 331
« Reply #16 on: June 16, 2007, 12:26:27 am »
how much for all the turbo parts? US shipped to california 93245 !!
Reply #17June 16, 2007, 03:32:41 am
aidan
« Reply #17 on: June 16, 2007, 03:32:41 am »
If by all turbo parts you mean as I listed above 'K14 turbo + manifold + downpipe, aux water pump, oil feed, and inlet manifold if required'
Then I have all apart from the elbow of the inlet manifold, I don't think the rest of the manifold is anything special, it'll just add size to the box which makes the shipping cost higher.
Anyway, £60 for all of the above. I will get everything together and make sure on etka that its a full system, though I don't have wiring for the aux water pump. I didn't have time to strip that much off the car.
Shipping i'll let you know, I need to find the smallest box it'll all fit in to keep costs down.
Reply #18June 16, 2007, 03:40:46 am
aidan
« Reply #18 on: June 16, 2007, 03:40:46 am »
dirtytom;
The pump is an 11mm, 20mm shaft DI mechanical pump from a non-turbo Perkins engine, it doesn't have an LDA but it has an 'RPM compensator'. Also has a KSB.
This information is from Tintin on here (thanks for the help on mtdi pumps), but basically you'll need an LDA like of a TD 1.6/1.9.
I never progressed with the project, all I know is it needs an LDA and a sprocket. Neither the 1.9 tdi nor the 1.6 IDI sprockets fits (the threaded section is somewhere in-between in size), maybe a 1.6 one will fit slightly modified.
I would like £50 for this, mainly to cover the cost of the expensive aluminium spacer plate. Shipping i'll have to check, depends on the size of the box.
Reply #19June 17, 2007, 01:52:39 pm
aidan
« Reply #19 on: June 17, 2007, 01:52:39 pm »
first post edited
Reply #20June 19, 2007, 10:15:29 am
Demons UK
  • 21
« Reply #20 on: June 19, 2007, 10:15:29 am »
Hey mate,
I'll have the GTD clocks off you.
I get paid tomoz so can pay you anytime after that?
Contact me here or through all_that_remains@hotmail. co.uk and we can sort things out?
thank mate.
Reply #21June 19, 2007, 12:50:40 pm
aidan
« Reply #21 on: June 19, 2007, 12:50:40 pm »
Hi mate, just so happens i'm going to Ledbury on Sunday afternoon, i'll be coming off M5 J8, right by you if you want to meet up?
Reply #22June 29, 2007, 04:37:42 pm
Hillshy
  • 103
    • http://www.hillshy.co.uk
« Reply #22 on: June 29, 2007, 04:37:42 pm »
Hi aiden,
have you still got the turbo, i really need one asap, can you drop me a pm?
Hillshy T25 caravelle "Hilli" currently thrashing 1.6 td GTD engine
NOT SO FRIGGEN HILLSHY ANYMORE!
15psi of BOOST set my c'velle free
Reply #23July 01, 2007, 09:58:48 am
aidan
« Reply #23 on: July 01, 2007, 09:58:48 am »
First post edited again
