General Information
General
Tranny to back up the 1.9AAZ
Topic: Tranny to back up the 1.9AAZ (Read 5912 times)
April 03, 2007, 06:12:37 am
stewardc
April 03, 2007, 06:12:37 am »
My Mk 1 Caddy is nearing the point where I'll need a good tranny to back the 1.9AAZ I'm building. Any suggestions for a good strong transmission for a Mk 1? Will the pre-cable-shifter Mk 3 bolt into the Mk 1?
April 03, 2007, 01:00:26 pm
April 03, 2007, 01:00:26 pm »
mk3 020s bolt directly into mk1s with the exception of the input spline being larger... but you just need a different clutch disc, thats all. oh yeah and you have to change the linkage thing for the shifter... the little c thing with the 2 ball joint deals on it, just switch over to all the mk1 stuff. the only other issue you might have is with the reverse light which sometimes has a different switch... regardless this isn't a major issue.
April 03, 2007, 03:12:41 pm
SMOKEYDUB
April 03, 2007, 03:12:41 pm »
what about the transmission mount itself you may have a problem i think some mk3 and eve mk2s wont have the holes necessary to bolt on mk1 brackets
why not just use your origonal one they are pretty strong.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
April 03, 2007, 03:50:53 pm
BlackTieTD
April 03, 2007, 03:50:53 pm »
i have a mkII (1990) o2o on an AAZ in a mkIII with no issues. holds up fine.
i've also pounded the crap out of the fn o2o in my 1.6TD rabbit many times. i like the o2o's. plus fn and ff have a good long 5th.
i'd try whatever fits up easily and has the gearing you're looking for. as long as its a diesel trans it should hold up. if they start letting go, start looking for a more customized solution IMO.
AAZ mkI, yep!
April 03, 2007, 04:15:13 pm
April 03, 2007, 04:15:13 pm »
the difference is that some mk1 transmissions won't go into mk2 and mk3's because they don't have the necessary mounting stuff... but mk2 and mk3 trannies will go into a mk1 no problemo
April 04, 2007, 06:36:01 am
BlackTieTD
April 04, 2007, 06:36:01 am »
as smokey said i dont think the later mkII and most (not sure) of the mkIII do not have the holes needed for the mkI trans mount.
April 08, 2007, 05:00:35 pm
DieselSteed
April 08, 2007, 05:00:35 pm »
I have been running my AAZ with a mk1 tranny (code FF) for nearly two years with no problems. Although I have not yet had Giles mod a pump for me I believe it will still withstand the more powerful powerplant. I have heard that the Vw trannys can withstand up to 300 hp. (?!!!)
www.brokenvw.com
has the best info about rebuilding and other info I have found and has a chart with codes, ratios and compatible trannies.
A problem with close ratio tranny codes after 14102 (14 Oct 82) is SMS or Self Machining Syndrome. They used rivets to retain the pinion shafts instead of the circlips used on the earlier tranny, which came apart and self machined a hole in the case. Wide ratio trannys did not have the problem but you may have troubles with mounts.
When my lady really wants to get me in the mood, she rubs a little diesel behind her ears.
April 09, 2007, 01:52:30 am
carrizog60
April 09, 2007, 01:52:30 am »
does anyone adapted a 1.9 tdi gearbox to a 1.6/1.9td?
i would like to have the long ratios but i dont know if it can be done easy and cheap...
it sucks to have all that power and still be passed on the freeway by car with far less hp... :evil:
Portugal
April 09, 2007, 05:42:38 am
April 09, 2007, 05:42:38 am »
www.patatron.com
sells tranny mounts for the A1 chassis, I'm not sure what style the TDI trannys are (02A, 02J etc) but he might have what you need.
April 15, 2007, 04:19:26 am
stewardc
April 15, 2007, 04:19:26 am »
I got one. It's a DFP code from a 1996 Jetta. It has a 3.67 r&p and a .75 5th.
General Information
General
