General Information
Troubleshooting
Severe front end Vibration on 82' Rabbit diesel Pickup
Topic: Severe front end Vibration on 82' Rabbit diesel Pickup (Read 6041 times)
October 21, 2006, 06:06:04 pm
runabout
Newbie
October 21, 2006, 06:06:04 pm »
This is my first visit and posting so I hope I am not asking an old question. I just purchased an 82' Pickup (caddy) and the front end seems to shake a lot. The previous owner said that his brother had the same model and it did the same thing. Is this common? The CV joints look good and the tires don't appear to be seperating or missing balance weights. Any ideas? I would be very thankful.
October 21, 2006, 08:27:03 pm
Slave2School
October 21, 2006, 08:27:03 pm »
Not a rabbit (my car is a GOLF) but I had a bad inner CV joint, and no way to tell till it was off the car. Vibrated hardcore under load and not really noticeable whiel just cruising. If the tire rod ends have never been changed on your rabbit that could also be something wroth looking into.
Waiting for a bigger better diesel to come along.
2002 ford focme wagon
October 21, 2006, 09:38:19 pm
October 21, 2006, 09:38:19 pm »
i had a broken motor mount... when engaging 1st from a dead stop, the engine would shake violently... sometimes... :twisted: i put a solid mount from a passat... supposedly those last forever??? bit more vibrating though... but longetivity is worth it
** forgot to mention that my car shaked in every gear on sudden acceleration. ex: coasting in 5th, then flooring it the car would vibrate a bit... not much but noticeable. The worst was in reverse because it was the front motor mount.
October 22, 2006, 09:24:10 am
runabout
Newbie
October 22, 2006, 09:24:10 am »
Jtanguay and Slave2school,
Thank you for the suggestions. I am out of town and will check it out as soon as possible
October 22, 2006, 12:37:41 pm
October 22, 2006, 12:37:41 pm »
i think the easiest way to check for bad motor mounts, is to put it in gear, and rock the vehicle. look at the mount and how much it moves. it will move a bit, but not too much.
October 22, 2006, 12:45:06 pm
October 22, 2006, 12:45:06 pm »
October 22, 2006, 01:14:08 pm
TomB
October 22, 2006, 01:14:08 pm »
Is the shaking constant or under braking/load? The engine mount sounds like a distinct possibility though... Get somone to check as you apply load in gear (gently
) and see it looks like it's going to twist up and hit the bonnet....
Good luck,
Tom
1.6 Golf GTD - Chip Fat Powered!
October 25, 2006, 05:07:06 pm
runabout
Newbie
October 25, 2006, 05:07:06 pm »
Thanks
I will check the motor mounts this weekend and give you all an update. The vibration lets up when I go into a long sweeping right hander. Does that help?
October 26, 2006, 08:17:54 am
October 26, 2006, 08:17:54 am »
what about a left hander? if it vibrates in a left hander could be the right side bearing? does it shake going straight?
October 28, 2006, 09:58:40 am
runabout
Newbie
October 28, 2006, 09:58:40 am »
It definitely shakes going straight and at all speeds. I think that it shakes in left handers too.
October 28, 2006, 10:53:32 am
October 28, 2006, 10:53:32 am »
man... check your tires. i bet the belts are worn. if not that, then its probably struts/shocks.. i had a golf with bad rear shocks and it vibrated when going past 90 km/h. by 100km/h it felt like a nice massage... pretty scary :lol:
Reply #11
November 24, 2006, 03:03:55 pm
Toolbox
Newbie
Reply #11 on:
November 24, 2006, 03:03:55 pm »
If you have old tires on your car have them balanced or replaced. The difference is unbelievable, my car used to shake so bad above 60MPH that I couldn't listen to the CD player. After a blowout I got 4 new tires and could hit 90MPH before there was even a little vibration. (2 speeding tickets later I kinda missed the vibration) The same was true for my wifes car, only we just had them balanced and the shaking stopped.
In any case I would start your troubleshooting with the balancing. The shop I went to did all 4 for $10 because I took them off and brought them in.
1980 1.6 NA Rabbit
1926 Ford Model T Coupe Hot Rod (In progress)
Reply #12
November 24, 2006, 03:36:50 pm
Northern RD
Reply #12 on:
November 24, 2006, 03:36:50 pm »
Hmmm, a 24 year old vehicle with the front end shakes and no mention of how old any of the front end parts are: I wonder what it could be???
Unfortunatlywith so little to go on it`s almost impossible to say what it is exactly, it could be ball joints, tierod ends, superanuated front end bearings or a combination of all three and maybe more,..... :cry: :cry: ..
General Information
Troubleshooting
