Author Topic: This trubo..whaddaya think?  (Read 3859 times)
October 20, 2006, 07:46:44 am
syncroserge
  • 116
« on: October 20, 2006, 07:46:44 am »
it swallowed bit of cylinder head, valve, piston... :oops:
I've reused some in worse shape..but I was younger then  :oops:  :lol:
Westfalia Syncro '91 TDI se transforme lentement
mais sūrement en 16".
Jetta '97 TDI
Reply #1October 20, 2006, 08:25:24 am
Darkness_is_spreading
  • 288
« Reply #1 on: October 20, 2006, 08:25:24 am »
If that blade is chipped or cut up at all it will be a problem,  if the shaft isn't straight then there is another problem.   I would break the turbo apart and take a nice pic of the cold side  impeller.
The bigges problem I can see is if you do up a good motor,  and everything is perfect on the build up,  and you throw an ok turbo into it.......     and the turbine  decides to hit the turbine case....  and chips fly off                   :evil:   well  it's not pretty
83 Jetta 1.9 T (Project Darkness)
88 Jetta 1.6 NA (Dead/Crushed)
92 Jetta 1.6 T (Sleepin)
96 Golf 1.9 T (Parts Car + Mexican Rust Bucket)
Reply #2October 20, 2006, 10:30:06 am
syncroserge
  • 116
« Reply #2 on: October 20, 2006, 10:30:06 am »
The compressor is perfect and the shaft looks good and straight.
This is for a friend who's a little tight on cash right now but I
think I've convinced him to get a new tubine/shaft assembly.
None of the blades have material missing though just scratched
so it's tempting
Jetta '97 TDI
