Author Topic: Front end noise after panic stop  (Read 7050 times)
October 18, 2006, 02:30:42 pm
1slowvw
« on: October 18, 2006, 02:30:42 pm »
Well guys the title pretty much somes it up. Went to drive a friend home tonight(and it was raining quite hard) and ended up making a panic stop to avoid running a stop sign. ended up locking up the front passenger side tire before comming to a stop. When I took off again there was a loud clunking comming from the front passenger side almost like a CV joint or something. so i took off slowly and started limping it back to residence. So after a hard right turn the noise disapears and everything seems to work fine other then the fact the car pulls to the right under braking a little bit. Anyway im hopping somone can give me an idea about what might have caused this noise because I'm kind of confused. Oh yeah the car is a 95 Golf AZZ and i just instaled a Supersport cup kit(if that could be a cause).
                                                              1slowvw
Reply #1October 18, 2006, 03:33:23 pm
Darkness_is_spreading
  • 288
OK
« Reply #1 on: October 18, 2006, 03:33:23 pm »
Well  you gave some good details,  does the car pull at all when normally driving.  When you locked up the front tire,  maybe you damaged the Caliper,  and when you break, it drags more on that side because it may be damaged some how.
But I would check everything and report back anything weird....
83 Jetta 1.9 T (Project Darkness)
88 Jetta 1.6 NA (Dead/Crushed)
92 Jetta 1.6 T (Sleepin)
96 Golf 1.9 T (Parts Car + Mexican Rust Bucket)
Reply #2October 18, 2006, 04:42:37 pm
1slowvw
« Reply #2 on: October 18, 2006, 04:42:37 pm »
I'm hoping to be able to check it out tomorrow. Its raining tonight and im living at university so i dont have access to a garage. If anyone else has any ideas i would love to hear them.
Reply #3October 18, 2006, 05:24:30 pm
« Reply #3 on: October 18, 2006, 05:24:30 pm »
does it pull either way during normal driving?
Reply #4October 18, 2006, 05:52:11 pm
1slowvw
« Reply #4 on: October 18, 2006, 05:52:11 pm »
No it doesent pull if im just rolling, but if i give it gas or break it does, it feels like i have a really bad ball joint and its going in and out of alignment. if that makes any sense at all.
1slowVW
Reply #5October 18, 2006, 06:34:13 pm
Doug
clunking
« Reply #5 on: October 18, 2006, 06:34:13 pm »
Sounds like a lower ball joint is done.
Reply #6October 18, 2006, 06:41:14 pm
1slowvw
« Reply #6 on: October 18, 2006, 06:41:14 pm »
That is what it feels like but it doesent explain the loud clunking noise when I took off.
1slowvw
Reply #7October 18, 2006, 06:56:27 pm
« Reply #7 on: October 18, 2006, 06:56:27 pm »
Jack the wheel up and give it a wiggle. The loud clunking may have been your suspension settling, and was possibly unrelated
Reply #8October 19, 2006, 05:36:38 am
Doug
clunking
« Reply #8 on: October 19, 2006, 05:36:38 am »
Check the strut top mount bearing too.
Reply #9October 19, 2006, 08:51:19 am
saurkraut
  • 904
« Reply #9 on: October 19, 2006, 08:51:19 am »
I wonder if you lost the inboard control arm bushings or sheared the bolt and the arm is moving enough to put the sway bar into the axel.  Don't drive it until you can see whats broken and fix it.  If you can feel a toe change while driving, something is really wrong.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
'86 Audi 5000 Turbo Quatro Wagon
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #10October 19, 2006, 09:00:53 am
1slowvw
« Reply #10 on: October 19, 2006, 09:00:53 am »
Having a new ball joint put in today. And having it looked over by a mechanic(I hate letting somone else work on my car) so well see how much this will cost me. Il let you guys know as soon as i find out what was causing the noise.
Just wanted to let you guys know that it was the brake disk that broke. broke clean in two must have hit a puddle when i was breaking and well you guys know the rest. Anyway thanks for all the help.
                                                          1SlowVW
