Author Topic: Franken Build, Need Parts Help 1y and 1.6TD Mixup  (Read 13975 times)
Reply #30Today at 07:28:09 am
vwpieces
  • 45
Re: Franken Build, Need Parts Help 1y and 1.6TD Mixup
« Reply #30 on: Today at 07:28:09 am »
Looks like you remembered to put the T-bolt in the waterpump before putting the alternator bracket on.
Ha. Hate it when I forget that after all these times.
Moving right along quickly.
 It looks great.
Took me hours to find the little standoff for the MK2 upper timing belt cover.
 But I got a chance to organize fasteners, inventory the hoard and did actually find one.
Is you lower timing belt cover from an AAZ or AHU?
 I'm thinking AHU.
Of course I remembered the "T" bolt.
After the alternator mount was on.
But you missed the upsidedown motor mount.
This thing has been apart and back together so may times now. Just wait till the next time it's apart to address that too. And that, and that ..
Reply #31Today at 10:06:38 am
vwpieces
  • 45
« Reply #31 on: Today at 10:06:38 am »
i sold him some of these bits, the lower cover is off of the ahu that's currently in my car. I think the aaz and ahu lower covers are the same or close enough, i used the aaz one on my ahu because it was already trimmed for running a v belt. 1.6 lower cover is different, the split where it meets the upper cover is more of a straight line where the aaz/ahu has kind of a z pattern
Only remember ya saying TDI, don't know engine code. Had to open center hole for the cast 068 pulley. Might need to remove the metal ring to clear the V belt too. Need to dig out an alternator. 90A on Jabbit, same bracket, and had to custom make an adjustment arm. Going same route here.
And had to post this one.
« Last Edit: Today at 10:28:26 am by vwpieces »
