1.6 TD Oil pressure light and no vacuum at start up (sometimes)
Pages:
Topic: 1.6 TD Oil pressure light and no vacuum at start up (sometimes) (Read 8667 times)
Reply #15
August 05, 2021, 02:14:35 pm
33B
Bosnian with a money pit aka VW Passat 1987
Re: 1.6 TD Oil pressure light and no vacuum at start up (sometimes)
Reply #15 on:
August 05, 2021, 02:14:35 pm »
Thanks for the info. It's a turboed NA with mech lifters, no oil jets. The oil pump is bigger then the original one that i removed.
https://ibb.co/W29QkWB
https://ibb.co/bbKkNkF
Last Edit: August 05, 2021, 02:16:31 pm by 33B
1987 Passat B2 (33B)- 1.6TD JR, Audi 80 b4 front suspension and power steering. 280mm brake discs with 54mm calipers front. Rear MK3 disc setup with golf mk5 calipers.
Reply #16
August 05, 2021, 02:35:13 pm
Reply #16 on:
August 05, 2021, 02:35:13 pm »
If you don't have the hydro lifters or oil jets then the 30mm pump is fine.
Reply #17
August 05, 2021, 07:46:11 pm
Moderator
4549
Reply #17 on:
August 05, 2021, 07:46:11 pm »
What? 30mm is fine? Bigger is always better. Well unless it is a bill to the electric co.
Pages:
