Author Topic: Oil Pan Bolt Under Tranny  (Read 3754 times)
July 08, 2021, 07:19:58 am
mstephenson
  • 47
« on: July 08, 2021, 07:19:58 am »
1.9 1Y
5-speed
One of the two oil pan bolt holes located under the tranny is cross-threaded. Do I need to unbolt and move tranny to retap hole or can I notch the tranny to get a straight tap? Or is there another, easier way?
thanks.
Reply #1July 08, 2021, 08:27:11 pm
Re: Oil Pan Bolt Under Tranny
« Reply #1 on: July 08, 2021, 08:27:11 pm »
What do you think about using the next size of the bolt but make it a self-tapping one?  Be easier than cutting a clearance hole I would expect.  The oil pan bolts are 6 mm I think, You could upsize to 7 mm.
Just thoughts.
Reply #2July 09, 2021, 04:44:14 am
mstephenson
  • 47
« Reply #2 on: July 09, 2021, 04:44:14 am »
Thanks. That sounds doable. Only the first two threads or so are crossed. The idea of botching this is not appealing.
m
