Author Topic: CJAA Conversion?  (Read 7667 times)
May 14, 2021, 01:28:29 pm
Bad Actual
CJAA Conversion?
« on: May 14, 2021, 01:28:29 pm »
I've got a couple Jetta's that I'd like to pull the CR TDI's from, convert them to mTDI's with all mechanical control for the turbos. Has anyone done this yet?
Reply #1May 14, 2021, 10:13:27 pm
Re: CJAA Conversion?
« Reply #1 on: May 14, 2021, 10:13:27 pm »
I do not think that anyone has done an mTDI CR yet.  I've considered it.  It would require a fair amount of custom work but I believe would actually be doable.  The way I would do it is use the ALH accessory bracket, use a custom intake manifold, and make whatever adapters were necessary to fit fully mechanical injectors.
Reply #2May 18, 2021, 11:55:45 am
Bad Actual
« Reply #2 on: May 18, 2021, 11:55:45 am »
I have two of these, one running, one is not (pulled from a wreck). I don't have a problem pulliing together the parts to test out fitments, etc. Let me get the ugly one on a stand first and start getting some meaningfull measurements, pics, videos put together.
- Would not one of the pumps for a 1.9 work, with some larger injectors?
- Can I control how rich/lean the mixture runs via cable/lever? (Like aviation mixtures) I hit lots of mountains (Is it even necessary?)
Reply #3May 18, 2021, 01:51:00 pm
« Reply #3 on: May 18, 2021, 01:51:00 pm »
If the ALH bracket will bolt up (and it looks like it will) then getting a pump that would work well is quite easy.  The AAZ pumps would not be a good choice.  There are others that would be much better, e.g. Land Rover 300TDI, LT28, Cummins 4BTA, etc...  Injectors that fit and work is a much larger hurdle.
Reply #4May 18, 2021, 01:52:07 pm
« Reply #4 on: May 18, 2021, 01:52:07 pm »
...and the injection pump IS the mixture control.  Thinking of it as rich/lean on a diesel is not really helpful, though, IMO.
Reply #5January 17, 2022, 01:29:10 pm
Chuck1978
  • 77
« Reply #5 on: January 17, 2022, 01:29:10 pm »
https://youtu.be/DeZXeo-qnzA
DONE!
H Pump.
"Jhon Doe"
He's in Europe somewhere.
Reply #6January 17, 2022, 06:28:40 pm
« Reply #6 on: January 17, 2022, 06:28:40 pm »
Flames out the exhaust ports!!!!   You will need to watch the EGT gauge for sure.
