Author Topic: IDI pump  (Read 3766 times)
April 03, 2021, 11:34:12 pm
Colony
  • 2
IDI pump
« on: April 03, 2021, 11:34:12 pm »
Hello
Can some1 tell me what function have this electronic part on pump?
Where electric impulse go? I dont have ECU on car but have something called 357906121 Exhaust gas recirculation control unit for Volkswagen Passat B3.
Engine code: AAZ
I have some vibration on idle and it goes away if I get revs higher . Engine AAZ 1.9TD 1992 Passat B3
« Last Edit: April 05, 2021, 03:34:18 am by Colony »
Reply #1April 04, 2021, 11:21:21 am
Re: IDI pump
« Reply #1 on: April 04, 2021, 11:21:21 am »
Having never seen such a pump I have absolutely NO IDEA.  Sorry, I defer to others.
Reply #2April 04, 2021, 03:11:53 pm
sgnimj96
  • 185
Re: IDI pump
« Reply #2 on: April 04, 2021, 03:11:53 pm »
looks like it bumps up the idle,  I bet if you could see under that top cover the wire goes into you'd figure out what it does.
81 Scirocco 1.6D (conversion)    86 Gofl 1.6D      2003 Golf Tdi   1985 300TD
Reply #3April 04, 2021, 09:09:24 pm
  • 2926
Re: IDI pump
« Reply #3 on: April 04, 2021, 09:09:24 pm »
 What you circled is probably just a plug holder.
 The wire probably goes up to a throttle position sensor.
 Complete guess, I have no experience with this pump.
 Might be handy for an electronic VNT-15 turbo controller.
Reply #4April 04, 2021, 09:19:40 pm
Colony
  • 2
Re: IDI pump
« Reply #4 on: April 04, 2021, 09:19:40 pm »
UPDATE
I found out more. When you disconnect this plug on pump egr solenoid stops working and egr shut closed on idle. So this is some part of egr sistem.
Reply #5April 05, 2021, 08:30:01 pm
rabbid79
  • 684
Re: IDI pump
« Reply #5 on: April 05, 2021, 08:30:01 pm »
My vote is throttle position sensor too. My guess is that the EGR behavior you noticed was in response to the system losing contact with the TPS when you unplugged it.
'15 WRX
Reply #6April 16, 2021, 07:25:25 pm
thomas m
  • 144
Re: IDI pump
« Reply #6 on: April 16, 2021, 07:25:25 pm »
I thought that my 1991 MK2 pump was unnecessarily complex.
That one makes mine look like a Tinker toy!!
320,000 miles
