Author Topic: nw shiny ccv valve, but only 1 outlet?  (Read 2214 times)
June 01, 2006, 11:23:43 pm
Cheesetoast
  • 285
« on: June 01, 2006, 11:23:43 pm »
On my engine there is 2 hoses coming off the pcv vent, one from the crankcase and one that goes to the intake.  I bought the aluminum pcv filter, it  only has one inlet/outlet, should I unplug one of those 2 hoses or do I have the wrong item?
Reply #1June 01, 2006, 11:25:25 pm
Cheesetoast
  • 285
« Reply #1 on: June 01, 2006, 11:25:25 pm »
the other option i was thinking wiht installing a T so i can plug both in.  Either that or plug the one going to the intake, but don't i need that connected?
Reply #2June 02, 2006, 06:12:00 am
QuickTD
  • 1156
« Reply #2 on: June 02, 2006, 06:12:00 am »
You need this one,
 http://www.stancomachine.com/CCVII.htm
You have the A4 version. If you wanted to install a "T" it would need to go on the bottom, where the filter plugs into the valve cover.
Reply #3June 02, 2006, 05:50:12 pm
Cheesetoast
  • 285
« Reply #3 on: June 02, 2006, 05:50:12 pm »
:x  guess i'll return it...
