Author Topic: WTB power steering bracket & pulleys  (Read 7733 times)
December 15, 2018, 01:39:08 pm
MarkMac
  • 2
« on: December 15, 2018, 01:39:08 pm »
Swapping a AAZ into an old Willy's. The engine I have has A/C. I understand there is a PS and Alternator setup that uses a V belt. Would be interested in the parts required to convert.
Reply #1December 15, 2018, 01:47:18 pm
masterbeavis
  • 88
Re: WTB power steering bracket & pulleys
« Reply #1 on: December 15, 2018, 01:47:18 pm »
There are two generations I’m aware of that have what you need. Do you have a compressor you’re married to?
I have an AC setup that was removed from from a 91 Jetta 1.6 turbo diesel with factory AC that utilized Vee belts, and a Sanden 5 piston compressor. I think I have a York setup from a Quantum too, but I can’t guarantee I have all of the parts.
81 Caddy Diesel, 84 Jetta Diesel, 98 Jetta GLS, 99 Jetta GLX,, 95 Golf.
Reply #2December 15, 2018, 09:09:36 pm
  • 2926
« Reply #2 on: December 15, 2018, 09:09:36 pm »
Would that be the same as the ones on the MK2s?
I believe there was a small pully stuck to the waterpump pully, the belt went from crank to power steering then waterpump.
Do you have the crank pully setup for 2 v-belts?
Reply #3December 16, 2018, 08:57:33 am
masterbeavis
  • 88
« Reply #3 on: December 16, 2018, 08:57:33 am »
The setup I have was bone stock MK2. IRC the crank drove the water pump, AC and alternator, the water pump drove the power steering.  It’s been a minute since I’ve pulled it all off, I’ll need to think about it again later and get pics of another car with the identical setup.
Reply #4December 16, 2018, 09:59:36 pm
MarkMac
  • 2
« Reply #4 on: December 16, 2018, 09:59:36 pm »
I am not married to a compressor, I want to eliminate the AC. If you have a v belt solution, that would be great. Let me know, thanks.
« Last Edit: December 18, 2018, 02:48:11 pm by MarkMac »
Reply #5December 18, 2018, 06:06:41 pm
  • 2926
« Reply #5 on: December 18, 2018, 06:06:41 pm »
The MK2 AC delete is pretty easy,.. using the stock bracket, alternator and even the same AC belt.
 It's around here somewhere.
 I'm pretty sure the power steering ran off a second, smaller diameter pully.
Both pullys cast into the stock harmonic balancer.
  I'm also pretty sure I have all the brackets and pullys.
 All except the harmonic balancer pullys which I won't part with because I need them for non-power steering cars.
 It'll be a week, but I'll take a look in the pully pile and the bracket bucket,.. and get some pics.
Reply #6January 05, 2019, 08:20:14 pm
  • 2926
« Reply #6 on: January 05, 2019, 08:20:14 pm »
Hey I found them.
 powersteeringbrackets by vwfatmobile, on Flickr
That little pully goes on top of the water pump pully.
 I know you don't want the pump. Might even be easier to see the rest of the brackets if it wasn't in the picture.
Only a few bolts and a crank pully left to make it complete.
Reply #7January 06, 2019, 05:00:15 pm
« Reply #7 on: January 06, 2019, 05:00:15 pm »
Glad you found em.  And it looks like it goes well with crackers, grapes and MMMMMMM BACON!
Reply #8January 07, 2019, 08:55:08 pm
  • 2926
« Reply #8 on: January 07, 2019, 08:55:08 pm »
 Ah, you caught my subliminal sales trick. ;D
 Put a picture of bacon in the background, ha.
Some cool whip and chicken in a biskit doesn't hurt either.
That's funny, I hadn't noticed I did that,... but will continue to do it from now on because that bracket looks delicious and the pully looks hot.
Reply #9January 08, 2019, 07:32:07 pm
« Reply #9 on: January 08, 2019, 07:32:07 pm »
Crackers and Beer, Note the Bud Light and Coors there on the right!
Reply #10February 19, 2019, 05:16:57 pm
  • 2926
« Reply #10 on: February 19, 2019, 05:16:57 pm »
It worked!
 Sent it the other day.
 He even bought the pump.
 Can I supersize that for ya?
 ha.
