mTDI Mechanical TDI Conversions
Ahu mtdi knock
Topic: Ahu mtdi knock (Read 6172 times)
August 12, 2018, 04:36:22 pm
Meilleur
Newbie
Ahu mtdi knock
August 12, 2018, 04:36:22 pm »
hellos
i have an ahu with a cummins pump 4bt 11mm head tdi.
he is timing at 1mm ip
he has a clacking noise when you give fuel!
what could be the cause?
Sorry I’m français!!
https://youtu.be/3hJ7esUsLZk
Last Edit: August 12, 2018, 04:39:40 pm by Meilleur
August 12, 2018, 05:39:42 pm
Re: Ahu mtdi knock
August 12, 2018, 05:39:42 pm »
Cummins 4BTA pumps had 12mm plunger/head assemblies. Because of the larger plunger the fuel is delivered in a shorter injection event so the clatter is more pronounced. When I listened to your engine, though, the steady louder lower frequency knock sounds like a bad injector.
August 12, 2018, 05:51:54 pm
Meilleur
Newbie
Re: Ahu mtdi knock
August 12, 2018, 05:51:54 pm »
https://youtu.be/PhnGbwfbBz4
thank you for your answer here is another video.
Envoyé de mon iPhone en utilisant Tapatalk
August 13, 2018, 08:46:57 am
Re: Ahu mtdi knock
August 13, 2018, 08:46:57 am »
Wind noise makes it a bit hard to hear, but it sounds fine/normal to me in that video.
August 13, 2018, 07:55:23 pm
Moderator
4549
Re: Ahu mtdi knock
August 13, 2018, 07:55:23 pm »
Wind was a bit hard to filter out. I wasn't sure that there was a knocking noise that was abnormal. Maybe a listen with at solid rod from ear to injector will help find any that are louder than the others. I use a breaker bar and that seems to work well enough.
Timing of 1.0 mm? Could a change one way or the other make a slight difference for you?
May 13, 2019, 01:11:58 pm
byronEsset
Newbie
Ahu mtdi knock
May 13, 2019, 01:11:58 pm »
Easiest route is to use the sd16v compressor on the AHU, an yes you will have to clearance the core. You could probably use the cabrio compressor but I am positive that would a larger undertaking.
There are adapters available to use the cabrio hoses on the AHUs compressor.
https://thefreehreportonpsu.com/noocube-review/
Ahu mtdi knock
