mTDI Mechanical TDI Conversions
I got a M-tdi pump what's the plastic cover thing?
Topic: I got a M-tdi pump what's the plastic cover thing? (Read 9456 times)
May 11, 2018, 10:20:50 am
May 11, 2018, 10:20:50 am »
I bought an mtdi pump from William Smith.
It has a plastic cover over the fuel stop solenoid.
Here's a pic:
mtdipumpcleaner
by
vwfatmobile
, on Flickr
Pic of the front:
mtdipumpfront
by
vwfatmobile
, on Flickr
How do I remove it?
Tornado red, '91 Golf 4 door,
May 11, 2018, 09:33:15 pm
Re: I got a M-tdi pump what's the plastic cover thing?
May 11, 2018, 09:33:15 pm »
I have seen that before on a pump. I don't know what its function is and I don't know how to remove it. I do have confidence that you'll get it figured out, though.
May 12, 2018, 08:46:40 pm
Moderator
4549
May 12, 2018, 08:46:40 pm »
Plastic part, plus hacksaw blade might equal removal here.
May 17, 2018, 08:11:22 pm
May 17, 2018, 08:11:22 pm »
Ahhh the simple solution. I was going to grab the cutoff wheel.
My buddy ran the part number on the cover,.. I'll post it later.
It looks like 2 bolts clamp the plastic cover onto a normal 1.6D looking stop solenoid.
We'll see why there are 3 wires.
May 17, 2018, 09:37:33 pm
Moderator
4549
May 17, 2018, 09:37:33 pm »
Just looks like a cover for the stop solenoid really. Not really needed, three wires Eh? Will be interesting to know what it hooks up to.
May 18, 2018, 05:50:14 am
urmas
User+
May 18, 2018, 05:50:14 am »
AFAIK its the pump side component of the immobilizer. Some force and a chisel was involved when I took mine of.
'89 Mk2 AFN mTDI
June 01, 2018, 01:54:48 pm
June 01, 2018, 01:54:48 pm »
Hack saw worked great,.. just a regular 1-wire stop solenoid under there,.. more circuitry than I expected.
July 05, 2018, 10:07:55 am
July 05, 2018, 10:07:55 am »
Here's where I cut it:
mtdicutplastic
by
vwfatmobile
, on Flickr
The one bolt got cut but the other one loosened up and came out easily.
And here is the stop solenoid with the cover removed:
mtdistopsolenoid
by
vwfatmobile
, on Flickr
July 05, 2018, 08:10:47 pm
Moderator
4549
July 05, 2018, 08:10:47 pm »
What was the other circuitry used for? Any ideas?
July 16, 2018, 01:33:21 pm
July 16, 2018, 01:33:21 pm »
No, there was more circuit/chips than I expected
July 25, 2019, 06:40:08 am
Dino
User+
July 25, 2019, 06:40:08 am »
0 460 414 136 0460414136 VE4/11F2000R509-3
REPLACING PARTS:
ORDER NUMBER DESIGNATION CODE POSITION QUANTITY
2 460 283 001 SHAFT SEALING RING 2460283001 3 1
1 467 030 308 SUPPLY PUMP 1467030308 7 1
1 460 134 317 SUPPORT RING 1460134317 9 1
1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2
1 466 100 405 DRIVE SHAFT 1466100405 12 1
1 460 023 302 WOODRUFF KEY 1460023302 13 1
1 460 056 302 BUFFER 1460056302 15 2
1 466 317 301 TOOTHED GEAR 1466317301 16 1
2 460 102 001 SLIDING DISK 2460102001 17 1
1 460 232 328 ROLLER RING 1460232328 20 1
2 463 100 002 BEARING PIN 2463100002 21 4
2 460 300 005 ROLLER 2460300005 22 4
2 460 120 013 FRICTION WASHER 2460120013 23 4
1 463 103 316 ADJUSTING PIN 1463103316 24 1
1 463 120 359 RETAINING PIN 1463120359 25 1
1 461 310 300 RETAINING BRACKET 1461310300 26 1
1 460 140 334 CROSS DISK 1460140334 27 1
1 466 110 647 CAM PLATE 1466110647 29 1
2 460 223 001 SEAL RING 2460223001 30 1
1 463 104 498 TIMING-DEVICE PISTON 1463104498 31 1
1 463 218 312 SLIDING PIECE 1463218312 32 1
1 460 144 302 SHIM RING 1460144302 33 1
1 464 618 934 COMPRESSION SPRING 1464618934 34 1
1 460 100 178 PLAIN WASHER 1460100178 35 1
2 460 223 001 SEAL RING 2460223001 36 1
1 465 530 901 CLOSING COVER 1465530901 37 1
1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2
1 461 074 330 COVER PLATE 1461074330 39 1
2 463 414 001 TORX FILLISTER SCREW 2463414001 40 2
1 468 334 851 HYDRAULIC HEAD 1468334851 50 1
2 460 210 012 O-RING 2460210012 51 1
SELECTION GROUP SHIM 52 1
1 460 105 305 GASKET 1460105305 54 4
1 463 370 665 FITTING 1463370665 58 4
1 463 414 312 TORX FILLISTER SCREW 1463414312 60 2
1 460 210 008 O-RING 1460210008 66 1
1 467 134 686 MANIFOLD-PRESSURE COMP. 1467134686 67 1
1 463 163 150 PART LOAD GOVERNOR 1463163150 68 1
1 200 101 640 SHIM 1200101640 69 1
1 461 901 816 CONTROL LEVER 1461901816 72 1
1 463 315 310 FLANGE NUT 1463315310 75 1
ADJUSTING SCREW 88 1
1 461 015 302 GASKET 1461015302 92 1
1 461 907 159 FULCRUM LEVER 1461907159 95 1
2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1
1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2
1 460 105 307 GASKET 1460105307 105 2
1 464 613 611 COMPRESSION SPRING 1464613611 106 2
1 463 300 304 HEXAGON NUT 1463300304 107 1
1 463 590 311 GOVERNOR SHAFT 1463590311 108 1
1 460 210 313 O-RING 1460210313 109 1
1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1
SELECTION GROUP SUPPORTING DISK 111 1
1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1
1 460 100 370 SHIM RING 1460100370 114 1
1 460 422 324 SLIDING SLEEVE 1460422324 115 1
1 460 508 309 SEALING CAP 1460508309 116 1
1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1
2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4
1 460 210 349 O-RING 1460210349 129 1
1 463 461 306 SCREW PLUG 1463461306 130 1
1 460 105 306 FLAT SEAL RING 1460105306 131 1
1 463 453 306 BLEEDER SCREW 1463453306 132 1
1 460 225 081 O-RING 1460225081 133 1
1 460 225 082 O-RING 1460225082 134 1
1 460 362 468 CONTROL VALVE 1460362468 135 1
1 463 456 344 HOLLOW BOLT 1463456344 136 1
1 460 591 315 PROTECTIVE CAP 1460591315 140 1
2 410 508 006 PROTECTIVE CAP 2410508006 141 1
1 410 407 004 PROTECTION SLEEVE 1410407004 142 1
0 281 005 019 SOLENOID-VALVE CONTROL UN 0281005019 184 1
1 460 101 376 GASKET 1460101376 189 1
2 464 633 002 COMPRESSION SPRING 2464633002 200 1
2 915 021 004 HEXAGON NUT, DIN 934 - M14x1,5-8-A 2915021004 206 1
2 916 699 137 SPRING LOCK WASHER, DIN 128 - A14-FSt 2916699137 207 1
1 900 508 202 PROTECTIVE CAP 1900508202 209 1
1 464 651 461 COILED SPRING 1464651461 220 1
1 461 021 714 SUPPORT PLATE 1461021714 235 1
1 463 414 305 TORX FILLISTER SCREW 1463414305 237 2
2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 2
1 466 434 322 COUPLING HALF 1466434322 270 1
1 461 900 628 SWITCH LEVER 1461900628 289 1
1 461 900 627 SWITCH LEVER 1461900627 289 1
1 463 433 313 WASHER-AND-SCREW ASSEMBLY 1463433313 292 1
1 460 522 328 SPRING SEAT 1460522328 325 1
1 460 522 304 SPRING SEAT 1460522304 329 1
1 463 386 301 VENT FITTING 1463386301 336 1
1 460 558 303 PROTECTIVE CAP 1460558303 339 1
1 460 100 893 PLAIN WASHER 1460100893 346 1
1 460 210 322 O-RING 1460210322 392 1
1 463 462 308 SCREW PLUG 1463462308 393 1
1 464 736 300 CLAMPING BAND 1464736300 400 1
1 463 433 313 WASHER-AND-SCREW ASSEMBLY 1463433313 406 1
1 460 326 387 DRIVER 1460326387 408 1
1 461 098 346 FASTENING PLATE 1461098346 409 1
1 463 300 319 HEXAGON NUT 1463300319 410 1
1 467 217 359 POTENTIOMETER 1467217359 442 1
1 461 098 344 FASTENING PLATE 1461098344 443 1
1 463 433 320 WASHER-AND-SCREW ASSEMBLY 1463433320 444 2
SELECTION GROUP SHIM 452 3
1 464 616 956 COMPRESSION SPRING 1464616956 453 1
1 463 219 304 CONTROL SPOOL 1463219304 455 1
1 460 505 308 CLOSURE CAP 1460505308 471 1
2 912 702 197 CHEESE HEAD SCREW 2912702197 472 2
1 464 610 988 COMPRESSION SPRING 1464610988 477 1
1 460 421 302 GUIDE SLEEVE 1460421302 478 1
2 916 089 956 LOCKING WASHER, DIN 6799 - 3,2-FSt 2916089956 519 1
1 463 022 310 GUIDE ROD 1463022310 520 1
1 465 130 704 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465130704 800 1
1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1
1 460 591 313 SEALING CAP, RED 1460591313 808 1
2 420 580 005 SEALING CAP, RED 2420580005 809 1
1 467 010 552 PARTS SET THEFT PROTECTION 1467010552 825 1
Hello.
The black plastic part is at 184. I don't know if at 825 is the whole system.
Is that pump from a Land Rover? 0460414136?
Last Edit: July 25, 2019, 07:12:14 am by Dino
Reply #11
August 04, 2019, 12:10:31 am
Reply #11 on:
August 04, 2019, 12:10:31 am »
Yep, I got it from William Smith.
In the classifieds on here.
I have the engine now and should be putting it all together soon.
Reply #12
August 04, 2019, 12:29:52 pm
Dino
User+
Reply #12 on:
August 04, 2019, 12:29:52 pm »
Hello.
Thank you. I saw the ad,it was bumped by Jimbote. Thank you all.
I'll follow your conversion.
