Author Topic: 1.6d parts  (Read 3873 times)
January 10, 2018, 03:32:09 am
zuhandenheit
  • 196
1.6d parts
« on: January 10, 2018, 03:32:09 am »
It's time to start clearing out the garage.
The 1.6d in my van had a bad headgasket and was hydrolocked when I pulled it. The block and head is free to anyone who can pick it up (I'm in Jacksonville, Florida). The IP had a small leak but was working well.
Reply #1January 23, 2018, 02:17:49 pm
zuhandenheit
  • 196
Re: 1.6d parts
« Reply #1 on: January 23, 2018, 02:17:49 pm »
I just realized that I didn't explain that I'm parting out the whole motor. So, for instance, I have:
Injectors and lines
Injection pump (ran well but needs to be resealed, and the throttle lever is removed)
Pump bracket
Cylinder head
Intake and exhaust manifolds (for vanagon installation)
Block (rebuildable at least)
Vacuum pump (I think)
I still have almost the entire engine -- just let know what you need and I'll look.
Reply #2January 24, 2018, 07:26:17 pm
somovolksrods
  • 1
Re: 1.6d parts
« Reply #2 on: January 24, 2018, 07:26:17 pm »
can you send a pic of the intake manifold,
thanks
Reply #3January 29, 2018, 06:44:37 am
zuhandenheit
  • 196
Re: 1.6d parts
« Reply #3 on: January 29, 2018, 06:44:37 am »
Sorry for the delay -- I should tell you first of all that the plastic on the intake box is cracked (again, this is a vanagon diesel engine, in which the intake manifold is directly attached to the box.) If you just need the aluminum, I'm happy to let it go.
