Model Specific Questions and Info
MK3 Golf/Jetta and B3/B4 Passat
what transmission do I have
Topic: what transmission do I have (Read 9504 times)
July 24, 2017, 11:15:39 am
butch2000
User+
July 24, 2017, 11:15:39 am »
trying to figure out what trans I have , came out of a 1996 Jetta AAZ engine , there is no release bearing , there is a rod that pushes out of the input shaft ? I want to upgrade the clutch ,flywheel, but cannot find any info ?
July 24, 2017, 08:27:08 pm
Moderator
4549
Re: what transmission do I have
July 24, 2017, 08:27:08 pm »
Stamped on the bottom of the transmission housing, right up next to the engine will be a letter and number combination. When you find that go here: And you will have all the gear information you need along with some links. I think that is your next step.
http://scirocco.org/gears/
The numbers are the date of build in a strange German way of doing dates.
July 29, 2017, 12:44:28 am
July 29, 2017, 12:44:28 am »
The AAZ in the Jetta came with an 020 trans, I can't remember the actual code though. It's different from the 02A found on TDI and VR6 cars.
