Author Topic: Fuel filter location  (Read 2682 times)
April 16, 2017, 10:04:49 am
Gator79
  • 53
« on: April 16, 2017, 10:04:49 am »
Does it matter if the fuel filter is above or belove the injection pump?
Reply #1April 16, 2017, 12:03:48 pm
Re: Fuel filter location
« Reply #1 on: April 16, 2017, 12:03:48 pm »
For most of the Rabbits and such that I have seen the filter is below the IP on the fender.  Fuel is drawn up to the IP.  Not sure about vans.  I am unsure if you would have a problem mounting it above the IP.  My question is where would you find the room to do that?
« Last Edit: April 16, 2017, 12:05:53 pm by ORCoaster »
Reply #2April 16, 2017, 03:37:55 pm
« Reply #2 on: April 16, 2017, 03:37:55 pm »
It'll be fine as long as it isn't TOO high above. If you're mounting it to the roof you might have issues.
Reply #3April 17, 2017, 06:02:23 am
« Reply #3 on: April 17, 2017, 06:02:23 am »
Doesn't matter much. Once the system is full, there is as much downward pull as upward pull.
Reply #4April 17, 2017, 08:08:43 pm
« Reply #4 on: April 17, 2017, 08:08:43 pm »
Have you any idea what the vacuum pull in on the inlet of the IP?  I was thinking it was rather low like 3 lbs or so.
Reply #5April 18, 2017, 05:03:03 am
« Reply #5 on: April 18, 2017, 05:03:03 am »
IDK, but I rekon it's gonna be close to the resistance of the filter, plus the height above the tank (~20" h20, which is less than 1psi, if you want to measure in negative psi).
Reply #6April 18, 2017, 08:32:04 am
kljaja
  • 38
« Reply #6 on: April 18, 2017, 08:32:04 am »
I have it mounted next to downpipe on a firewall between downpipe and servo drum, as high as possible, works nicely
Going fast never killed anyone, suddenly becoming stationary, thats what gets ya
