Author Topic: Auto aaz?  (Read 2939 times)
May 21, 2016, 09:11:56 am
Ian0391
  • 119
Auto aaz?
« on: May 21, 2016, 09:11:56 am »
I've been thinking of building a 3 speed for my aaz but I've heard the starter won't clear the block, has anyone ever tried this?
Sent from my SM-G920W8 using Tapatalk
Reply #1May 22, 2016, 07:18:34 am
  • 5104
Re: Auto aaz?
« Reply #1 on: May 22, 2016, 07:18:34 am »
i know i have posted that it wouldn't fit before, but it can and it has been done, i think it just depends on the starter, but there are definitely aba swapped cars with the 3 speed automatic and if it fits with an aba then it will fit an aaz since they are both the newer block, u might just have to go through a couple starters
Reply #2May 31, 2016, 06:10:13 pm
Re: Auto aaz?
« Reply #2 on: May 31, 2016, 06:10:13 pm »
The diesel starter will not fit. I ground a lot of my block away trying to get it to fit but no chance. I also had to grind most of the turbo oil return bung away but it still wouldn't go. You will need to use a gas starter. I suspect with the exception of winter you will be fine.
Reply #3June 01, 2016, 03:28:20 am
Ian0391
  • 119
Re: Auto aaz?
« Reply #3 on: June 01, 2016, 03:28:20 am »
I was going to use a gas starter as it's thinner and I'm not planning on driving it I  the winter anyways. I'm starting to think I might be screwed though as my turbo is flipped upside down. Do you mean it hit the oil return banjo?
Reply #4June 01, 2016, 08:26:16 am
  • 5104
Re: Auto aaz?
« Reply #4 on: June 01, 2016, 08:26:16 am »
tdi has the same block, it depends on which starter you have.
http://vwdiesel.net/forum/index.php/topic,35969.0.html
Reply #5June 03, 2016, 09:15:35 am
Re: Auto aaz?
« Reply #5 on: June 03, 2016, 09:15:35 am »
I was using the diesel starter and it was hitting the oil return boss that is cast into the block.
The gas starter is a lot shorter so that won't be an issue.
I think you'll do fine with a healthy starter and warm temperatures. Synthetic oil might help, and a block heater might even be necessary but I wouldn't think so unless you are near the end of the season.
Reply #6June 03, 2016, 10:17:34 am
Ian0391
  • 119
Re: Auto aaz?
« Reply #6 on: June 03, 2016, 10:17:34 am »
Yeah this car won't see cold days and will have gold synthetic so I'm not to worried about the gas starter being able to spin  it.  I am worried about the solenoid hitting my turbo since the manifold if flipped. I wonder if I can rotate the starter so the solenoid I'd on the bottom. I'm picking up the trans and starter tomorrow so I'll find out soon what I'm dealing with
