Author Topic: Bucking while driving.  (Read 7097 times)
Reply #15April 25, 2016, 01:58:49 pm
BRimpossible
  • 20
Re: Bucking while driving.
« Reply #15 on: April 25, 2016, 01:58:49 pm »
Thanks I decided to hook up to 5 gal tank and put it on the bed.
Reply #16April 25, 2016, 07:34:05 pm
« Reply #16 on: April 25, 2016, 07:34:05 pm »
Yes better, much better to go with known clean fuel than route that dirty gunk around a bunch of times or pump it to another storage area.  Like it was said most fuel gets pumped through and is not used.  That is so the pump stays cool as it does its job.
Reply #17April 26, 2016, 02:50:00 am
BRimpossible
  • 20
« Reply #17 on: April 26, 2016, 02:50:00 am »
Unhooked the gas tank and used the 5 gal tank on the bed for temporary but found out that the hard lines or rubber lines before the fuel filter is clogged. Basically the ip is getting foam fuel so I'll need to reroute the fuel line again front of the hard lines before the fuel filter to see if that works better. Just struggling to see how I can make this work for temporary. I use this pickup everyday and I don't have much free time to clean up the whole fuel system.
Reply #18April 26, 2016, 08:13:12 am
« Reply #18 on: April 26, 2016, 08:13:12 am »
Sounds like your fuel lines may be your actual issue then...  Not sure about the Caddy, the Mk2 had a water separator near the rear axle that caused a lot of similar problems...
You CAN "polish" the fuel in your tank if you can get your hands on a transfer pump and a good fine filter with a  proper water separator - something like a Racor or whatever.  Set up the pump to suck out the tank feed, route through the filter and return it to the tank, leave it running overnight for a few nights.  I'd feel pretty confident to use the fuel at that point provided you don't have any signs of algae in the tank.
Reply #19April 26, 2016, 11:26:38 am
BRimpossible
  • 20
« Reply #19 on: April 26, 2016, 11:26:38 am »
Well took off the inlet fitting that goes to the fuel filter, it was clogged with dirt. Cleaned it up and now I have pure fuel coming to IP from the 5 gal tank. I still think I'm gonna clean up the gas tank and blow air in the hard lines to prevent that from happening again. Thanks everyone for your help. I can drive the caddy and actually enjoy it again.
Reply #20April 26, 2016, 12:14:05 pm
mtrans
  • 308
« Reply #20 on: April 26, 2016, 12:14:05 pm »
Did you clean mash in tank?
I`ll improve my English
Reply #21April 26, 2016, 06:37:09 pm
« Reply #21 on: April 26, 2016, 06:37:09 pm »
OK for now you are mobile and you know that there is crud in the tank that needs to come out.  I think I read that you are now using the original line for feeding the fuel filter.  That line is blown out clean and hooked to a temp 5 galloner?  That will get you by for ever if you don't mind the fuel risk of running out of fuel early, no gauge and potential for contamination.
Find some time and pull the tank or pump it out and clean the inside with filtered fuel.  That gob of dirt in the inlet line is all the evidence you need to show you have a dirty tank.
Reply #22April 27, 2016, 01:27:02 pm
BRimpossible
  • 20
« Reply #22 on: April 27, 2016, 01:27:02 pm »
Took the gas tank out, drained the fuel. Inside is very dirty and black on the bottom. Fuel sender unit has hard dirt built up on it even though it worked well. I'll buy a restoration kit for the tank so it will be clean again. Filter is black as well
Reply #23April 28, 2016, 12:51:07 pm
mtrans
  • 308
« Reply #23 on: April 28, 2016, 12:51:07 pm »
Great.
Reply #24May 07, 2016, 07:22:28 pm
  • 2926
« Reply #24 on: May 07, 2016, 07:22:28 pm »
Good point
how does the intank screen look?
Reply #25May 08, 2016, 08:44:09 am
mtrans
  • 308
« Reply #25 on: May 08, 2016, 08:44:09 am »
By reading on forum I remove first time on deal with tank,many years ago.
Never see point for our motor,it`s more eazy to change fuel filter.
Just mesh crimped on metal pick up tube 8mm in case of my Fiat
Reply #26May 08, 2016, 07:56:19 pm
« Reply #26 on: May 08, 2016, 07:56:19 pm »
It's not uncommon for algae to grow in the tank. It makes a black slime that will easily block the pickup screen which is why folks recommend checking it out. Mk2+ have an access hatch to get at the pickup making it simple enough. Not sure about Mk1.
Reply #27May 08, 2016, 09:02:15 pm
« Reply #27 on: May 08, 2016, 09:02:15 pm »
On the MK1 you just pull up the rear seat and then undo some screws and tap the sending unit to release it from the tabs.  Then you wiggle out the sending unit and you have a clear view and about a 3 inch hole to work in.  Just don't do it with more than a half a tank of fuel as it may be up on the sender end if not level.  Besides you want to be low on fuel to get the most gunk out you can.  Filter with some of those 10 micron socks inside a PVC tube it works for veg oil.
Reply #28May 27, 2016, 05:49:13 pm
Dubdoc
« Reply #28 on: May 27, 2016, 05:49:13 pm »
When you swapped engines, what did you do with the exhaust system?
