Author Topic: AHU Timing  (Read 5584 times)
January 26, 2016, 10:58:56 pm
dlnd5d
  • 3
AHU Timing
« on: January 26, 2016, 10:58:56 pm »
I just bought an AHU out of a 98 Jetta that came without a transmission or flywheel so I can't immediately identify TDC. Without tearing into the engine and putting a special rig on the number 1 cylinder, how do I find TDC? Would it work if I lock the pump and then mark the other pullers? Or is there enough slop/tension in the belt that could throw it off? I want to convert it over to an MTDI as soon as I can financially so I need to find TDC.
Reply #1January 27, 2016, 06:20:46 am
Re: AHU Timing
« Reply #1 on: January 27, 2016, 06:20:46 am »
There is waaaaayyyyyyyy too much slop in the pump lock to use it to make a TDC mark.  It's also possible that the pump is off any number of teeth so using it to determine TDC is utterly unreliable.  Doing so would be just asking for a ruined engine with bent valves, broken lifters, bent rods, etc...
There are various ways to accurately determine TDC and they have been discussed quite a few times on this forum.  I don't have the time or gumption right now to go into the details or find links.
