Author Topic: 1.6td wont start  (Read 4140 times)
May 18, 2015, 04:24:01 pm
grizzlygary
  • 11
1.6td wont start
« on: May 18, 2015, 04:24:01 pm »
Okay so im new to this forum first off hello everyone. So i bought a 1992 1.6td golf and it ran perfect when i drove it home and also the night of, than i went to start it up in the morning only to find it would not fire at all. So than i set out and bought new glow plugs and tried to gravity feed it to see if any air was in the lines and surely enough that was fine too (cracked injector lines at injectors and tightened back up when i was done) solenoid on pump works fine as well. I checked to see if the belt slipped but it was nice and new and tight. What is going on here?
Thanks
Reply #1May 18, 2015, 08:06:16 pm
Re: 1.6td wont start
« Reply #1 on: May 18, 2015, 08:06:16 pm »
Is it smoking while you crank?
Reply #2May 18, 2015, 08:49:30 pm
grizzlygary
  • 11
« Reply #2 on: May 18, 2015, 08:49:30 pm »
It is, i pulled the cold start and it sounded like only 2 cylinders would fire after alot of cranking
Reply #3May 18, 2015, 09:35:06 pm
« Reply #3 on: May 18, 2015, 09:35:06 pm »
Are you sure all of the new glow plugs are getting 12 VDC?  Is the fuse on the firewall blown?  Did the PO fab up individual wires for the plugs?
Sounds like you have fuel to all injectors but lacking heat enough on a cold morning to make it go bang.
With a tight belt I wouldn't expect poor timing as it was running fine previously.
Blow a gasket maybe?
Reply #4May 18, 2015, 09:45:07 pm
grizzlygary
  • 11
« Reply #4 on: May 18, 2015, 09:45:07 pm »
I should check if plugs are getting 12v and it hasnt been cold when trying to start it at all. Could be the headgasket but i couldnt imagine it just blew wide open the night before
Reply #5May 19, 2015, 05:13:18 am
air-cooled or diesel
« Reply #5 on: May 19, 2015, 05:13:18 am »
i find i need a shot of glowplugs even when its 90f out. can hot wire gps, run a cable from +term to gp buss bar, careful not to short out, have someone to crank as you gp.
Reply #6May 19, 2015, 05:46:47 am
« Reply #6 on: May 19, 2015, 05:46:47 am »
What's the outdoor temperature?
Is it cranking slow /fast?
Reply #7May 19, 2015, 07:12:46 am
grizzlygary
  • 11
« Reply #7 on: May 19, 2015, 07:12:46 am »
Outdoor temp is about 15-20c and i hade a battery charger hooked up to it on battery start so it was cranking over faaaaaast
Reply #8May 19, 2015, 04:07:03 pm
« Reply #8 on: May 19, 2015, 04:07:03 pm »
It could have some air trapped in it. The thermo valve on the fuel filter doesn't allow fuel (and as a result air) back to the tank until the fuel temp reaches a certain temp. You can try bleeding the injection lines again, or keep cranking, or have someone pull start you.
Make sure the glowplugs are getting power first though. How tight did you install them? If you over-torque them you can kill them fast. Probably not 1 day fast though.
Reply #9May 19, 2015, 07:09:05 pm
grizzlygary
  • 11
« Reply #9 on: May 19, 2015, 07:09:05 pm »
Ya it was the glow plugs its kind of a rats nest in there after the po installed hids and other silly things so i was looking at the wrong fuse
Reply #10May 19, 2015, 08:14:34 pm
« Reply #10 on: May 19, 2015, 08:14:34 pm »
Glad ya got it, now fix the rats nest you won't be sorry.  Electrical gremlins love living in those places and these things have enough of them as it is.  Clean all grounds some afternoon and you will also not be sorry.  It is just good preventative medicine.
Reply #11May 19, 2015, 08:20:29 pm
grizzlygary
  • 11
« Reply #11 on: May 19, 2015, 08:20:29 pm »
Yeah im definetly gettin on that soon, somehow theres no electrical gremlins it just really upsets my ocd to open the hood to that
