TDI Engine -General Info
putting AHU in mk1 can I use mk2 pulley system to be able to keep AC compressor
Topic: putting AHU in mk1 can I use mk2 pulley system to be able to keep AC compressor (Read 6299 times)
March 02, 2015, 07:01:25 pm
SR Heer
March 02, 2015, 07:01:25 pm »
Just wondering if with AHU in mk1 frame does one has to use its harmonic balancer with serpentine pulley or can they use mk1-2 nose crank and pulley system - wanting to keep AC with out altering eng bay
97 Passat 1Z, 98 Jetta AHU, 91 Jetta AAZ TD, and 81 Rabbit Pickup
March 02, 2015, 07:50:48 pm
Re: putting AHU in mk1 can I use mk2 pulley system to be able to keep AC compressor
March 02, 2015, 07:50:48 pm »
The timing belt pulley needs to be the AHU part, but I believe the balancer and the rest of the pulleys will bolt up fine. The accessory brackets will be the trouble spot I believe.
March 03, 2015, 07:51:46 am
March 03, 2015, 07:51:46 am »
You can run the mk1 accessories including pulleys on the AHU. Power steering is the only thing that would require some mods to work.
April 09, 2015, 07:51:15 am
GEE-BEE
April 09, 2015, 07:51:15 am »
ina enginnering has a mod to run th serp to a/c & waterpump with one belt
no p/s
new pulley, new tens arm
I ordered two each of these
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
