TDI intake on a 1.6td ?
Topic: TDI intake on a 1.6td ? (Read 4350 times)
January 26, 2015, 05:51:56 pm
jlpst94
January 26, 2015, 05:51:56 pm »
The 1.6td intake seems to be a terrible design. I'm looking at the Kerma TDI intakes and I'm wondering if that will mount on the 1.6 head? If not, does anyone have better options than the stock setup.
January 26, 2015, 06:22:19 pm
Re: TDI intake on a 1.6td ?
January 26, 2015, 06:22:19 pm »
Make your own using the ports from your intake with longer runners.
Round 2
January 26, 2015, 07:42:54 pm
Brian schanafelt
User+
January 26, 2015, 07:42:54 pm »
If you decide not to use the stock intake I would be interested in buying, in need of a intake to comple my build and cannot find one
89 gti converted to 1.6 td,
January 27, 2015, 06:22:45 am
scubagli
Newbie
January 27, 2015, 06:22:45 am »
A g60, or even a stock 8v intake may work on a 1.6. I had a g60 on my alh for years, I had to change the shape of the runners to D's for it to work on the tdi. That would be a problem for idi guys trying to use a tdi intake on a 1.6...tdi intake runners are D shaped.
Sent from my KFSOWI using Tapatalk
January 27, 2015, 07:08:01 am
jmaddocks
January 27, 2015, 07:08:01 am »
I have a G60 intake on one of my 1.6 motors. When it was still NA, it seemed to run a lot stronger with that manifold, but I don't have any dyno numbers to prove it. It runs very well with the turbo, but I have to remove the compressor from the Holset (in situ) to access the intake manifold bolts, which really sucks. There's not much room. I'm holding onto a stock 1.6TD intake manifold in case I decide to turbo the rabbit I just picked up for my daughter -- going for ease of maintenance vice outright power on that one.
'89 Jetta 1.6d HE200WG, ported solid lifter head, ARP studs, FMIC, 2.5" exhaust, lightened FW, ACT clutch
'79 Rabbit ABA swap, microsquirt
'91 Corrado 1.9L T3/T04e, ported 16v head, JE pistons, Scat rods, megasquirt, peloquin, E85, etc
January 27, 2015, 09:57:12 am
jlpst94
January 27, 2015, 09:57:12 am »
Looks like the Kerma intakes will bolt on the 1.6td head. Anyone think the upgrade is worth it? Any trouble with daily driving performance? Thanks guys
January 28, 2015, 05:46:07 am
TimpanogosSlim
Pretty dumb for a smart guy
January 28, 2015, 05:46:07 am »
pd150 and pd130 intakes fit too, fwiw
January 29, 2015, 06:16:21 am
January 29, 2015, 06:16:21 am »
Totally not worth the money on a stock or lightly modified engine IMO.
