Author Topic: 89 gti to 1.6td  (Read 24143 times)
January 24, 2015, 05:10:00 pm
Brian schanafelt
  • 35
89 gti to 1.6td
« on: January 24, 2015, 05:10:00 pm »
This is my work in progress 1.6 td gti intercooled, arp studs ko3 needing upgraded, hopefully he200wg , big oil cooler , 2.5 straight exhaust, sending giles a true td pump so he can work his magic. Switching it with my na pump..... Working towards 160 to 180 hp.... Gotta say fun little car now... Can't wait til I get done.... Still needing a few parts like t25 manifold to bolt up he200wg. And proper intake instead of the tdi one I have on now.... And in process of porting a new 1.6td head... Any Suggestions incouraged
« Last Edit: January 24, 2015, 09:33:06 pm by Brian schanafelt »
89 gti converted to 1.6 td,
Reply #1January 25, 2015, 08:49:22 am
  • 5104
Re: 89 gti to 1.6td
« Reply #1 on: January 25, 2015, 08:49:22 am »
nice build!  when you get a 1.6 intake, you should try and have it modefied like this  or since you are going with a new turbo, mount it so that you can fit a gas intake manifold, maybe even have a gas intake sent out to scientific rabbit for porting, only 125 dollars for stage 1
Reply #2January 25, 2015, 04:16:57 pm
Brian schanafelt
  • 35
Re: 89 gti to 1.6td
« Reply #2 on: January 25, 2015, 04:16:57 pm »
Dang that a bad ass intake did u make that one yourself?
Reply #3February 04, 2015, 06:59:43 am
Dopie
  • 5
Re: 89 gti to 1.6td
« Reply #3 on: February 04, 2015, 06:59:43 am »
nice intake 8)
Reply #4February 04, 2015, 08:01:33 am
  • 5104
Re: 89 gti to 1.6td
« Reply #4 on: February 04, 2015, 08:01:33 am »
sorry no, passenger performance used to sell those.
Reply #5February 04, 2015, 08:16:19 am
Brian schanafelt
  • 35
Re: 89 gti to 1.6td
« Reply #5 on: February 04, 2015, 08:16:19 am »
Damn I would like to get my hands on one of those..... Guess I'll have to fab one up
Reply #6February 05, 2015, 10:36:27 am
Diesel_Zuk
  • 182
Re: 89 gti to 1.6td
« Reply #6 on: February 05, 2015, 10:36:27 am »
It looks very simple to make, just need to cut a stock intake down, get some aluminum supplies, and tig it all together.
Reply #7March 19, 2015, 08:11:38 pm
Brian schanafelt
  • 35
Re: 89 gti to 1.6td
« Reply #7 on: March 19, 2015, 08:11:38 pm »
Started tearing into engine and found some stuff I wasn't happy with such as bearings and piston rings so decided to re do everything while I was that far into it, things I am doing: sent pump to giles for modification, sent pistons to be ceramic coated and dry lube on skirts(bonehead performance) polished crank, ported new head, sent k24 turbo to xsboost for new compressor and 360* bearing, intercooled , new oil pump, Windage tray(victor reins),  new bearings rod and non integrated main bearings(kolbenschmidt and glyco), new goetz rings, all new seals and gaskets(elring) new intermediate bearing(front) , all new hardware: arp rod bolts, have arp head studs, new main bolts SHCS... New oil feed and return lines, new boost gauge and egt( auto meter) new clutch(luk) running gti flywheel and clutch with big input shaft, 2.5 straight exhaust, k&n air filter, manual boost controller( going I dial to 20psi) ..... New wrist pin bushings, and I'm probably missing a few things haha.... Now the process of putting all back together
« Last Edit: March 19, 2015, 08:32:24 pm by Brian schanafelt »
Reply #8March 19, 2015, 08:14:04 pm
Brian schanafelt
  • 35
Re: 89 gti to 1.6td
« Reply #8 on: March 19, 2015, 08:14:04 pm »
Turbo and pump
« Last Edit: April 28, 2015, 08:24:13 pm by Brian schanafelt »
Reply #9March 19, 2015, 08:21:20 pm
Re: 89 gti to 1.6td
« Reply #9 on: March 19, 2015, 08:21:20 pm »
Sounds like a solid build! Make sure you post pictures as you get it together!
Reply #10March 19, 2015, 08:28:51 pm
Brian schanafelt
  • 35
Re: 89 gti to 1.6td
« Reply #10 on: March 19, 2015, 08:28:51 pm »
Ported head
« Last Edit: April 28, 2015, 08:22:58 pm by Brian schanafelt »
Reply #11March 19, 2015, 08:31:23 pm
Brian schanafelt
  • 35
Re: 89 gti to 1.6td
« Reply #11 on: March 19, 2015, 08:31:23 pm »
Polished crank
« Last Edit: April 28, 2015, 08:21:14 pm by Brian schanafelt »
Reply #12March 23, 2015, 06:48:41 pm
Brian schanafelt
  • 35
Re: 89 gti to 1.6td
« Reply #12 on: March 23, 2015, 06:48:41 pm »
Got pistons back from ceramic coating
« Last Edit: April 28, 2015, 08:16:04 pm by Brian schanafelt »
Reply #13March 23, 2015, 07:35:35 pm
Re: 89 gti to 1.6td
« Reply #13 on: March 23, 2015, 07:35:35 pm »
I like it
Reply #14March 23, 2015, 09:04:27 pm
Brian schanafelt
  • 35
Re: 89 gti to 1.6td
« Reply #14 on: March 23, 2015, 09:04:27 pm »
Ya it's getting there think I have all my parts I need.... Now the want list starts haha.... One thing  I would really want to find is the g60 valve cover or a Morosso one .... Seen some crazy prices.... I'm just not a big fan of the stamped steel.... I should get the block and rods out of machine shop tomorrow... Then it's go time... It's hard looking at a bench full of parts and the block is in machine shop......wtf
