Author Topic: 1Z Mtdi Boost  (Read 19017 times)
Reply #30September 29, 2014, 08:49:16 am
rodpaslow
  • 670
Re: 1Z Mtdi Boost
« Reply #30 on: September 29, 2014, 08:49:16 am »
I thought I'd add a couple notes
pulses out of VSS for MK3 - this is a Can 99 car is 6000 for 1 mile.
Ohms for fuel gauge is 33 at full, around 250-260 empty.
For the W- rotor has 12 lobes and with pulley sizes works out to around 18 pulses for setting the VDO tach I have.
I have looked for stuff like this on this site and others and it's always hard to find.
99' 1.9 1Z Tdi, hybrid pump -1.9 housing & rover internals, 2052 wastegate turbo,.25 hflox nozzles, SDI intake, CTN tranny
96' 1.6 TD Golf, Giles pump, VNT 17, Gas changed to Diesel, Air to Water Int.
Reply #31September 29, 2014, 08:51:57 am
rodpaslow
  • 670
Re: 1Z Mtdi Boost
« Reply #31 on: September 29, 2014, 08:51:57 am »
One more thing - a 2252 turbo is to big for a 1.9 - I only have stock injectors as a qualifying statement.  At full fueling I get 5 psi boost at most.  I'm looking for a 2052 with a  wastegate, to test next...
Reply #32September 29, 2014, 09:01:26 am
Re: 1Z Mtdi Boost
« Reply #32 on: September 29, 2014, 09:01:26 am »
When I was still thinking of going wastegate the GT2056 was seeming like a good option.  The compressor map fits the engine a little better than the 2052 variants, especially if you are planning on running higher than stock boost.
Reply #33September 30, 2014, 08:54:57 am
rodpaslow
  • 670
Re: 1Z Mtdi Boost
« Reply #33 on: September 30, 2014, 08:54:57 am »
The 55 trim .53 ar looks better than the 2052.  thanks
definitely looking for higher than stock boost - T25 flange is currently on the car so the 2056 is just a bolt on - outlet will need a bit of fabing.
