Author Topic: Mk2 slow cranking  (Read 4513 times)
July 03, 2014, 12:46:25 pm
Diesel_Zuk
  • 182
Mk2 slow cranking
« on: July 03, 2014, 12:46:25 pm »
Here is what I know: I was trying to start my 91 ecodiesel after swapping to a turbo pump, when one day, while cranking, the cranking speed suddenly dropped. I was confused, as I just charged the battery overnight. I checked all my connections, nothing loose, so I pulled the starter and took it to a shop and had it rebuilt. They charged me for brushes and a starter drive. Took it home, put back on, same thing, slow crank. I did not crank it for more than 5 seconds before looking online and seeing people say to replace starter bushing. Did that. Same thing. I put jumper cables directly from negative on the battery onto starter body as a ground. Then the positive onto the solenoid. Still nothing. I put a mk3 tdi starter on, still slow cranking, except I did not try jumping the tdi starter directly to the battery. Where do I go next? I can turn the engine over by hand with a ratchet on the crank, and it turns nice and easy, it's not locked up or anything. I checked timing, and rechecked timing, it's spot on. What do I check next?
Reply #1July 03, 2014, 02:06:35 pm
Re: Mk2 slow cranking
« Reply #1 on: July 03, 2014, 02:06:35 pm »
IF YOU DID THIS
And haven't taken it back to the shop to demo the fact it isn't working then I would ask why not.  You paid for a serviceable starter and you don't have one.
Time to go back where you spent your money and get what you paid for.
Reply #2July 03, 2014, 02:20:23 pm
Diesel_Zuk
  • 182
« Reply #2 on: July 03, 2014, 02:20:23 pm »
It is better than before, but still nothing like it once was.
Reply #3July 11, 2014, 09:35:47 am
LOBOTAC
  • 36
« Reply #3 on: July 11, 2014, 09:35:47 am »
Check and/or replace your battery cables.  I had a similar situation after last clutch change, everything worked just fine prior to pulling it apart to replace clutch.  After reassembly, had very slow cranking.  I jumped with cables as you have from the battery to frame and starter.  Performed voltage drop check everything checked out normal.  Cleaned all grounds and connections.  I was pulling my hair out, it was driving me crazy that I couldnt figure out the problem.  Finally as a last ditch effort before towing it to a shop I replaced both cables from the battery and that solved all of the problems.
'90 Jetta GL 1.6NA
'98 Jetta K2
'91 Isuzu p/u 4X4
'81 Caddy 2.0 ABA
Reply #4July 11, 2014, 01:44:22 pm
  • 2926
« Reply #4 on: July 11, 2014, 01:44:22 pm »
Crank and crank or click and click for quite awhile.
 Then go feel for hot spots on the cable connections,.. both ends of cables.
