General Information
General
Harbor freight compression tester?
Topic: Harbor freight compression tester? (Read 4253 times)
April 23, 2014, 10:51:13 am
Smoker
April 23, 2014, 10:51:13 am »
To buy or not to buy? I did a quick Google search and found advice both ways as usual. Figured I'd check with you guys specifically.
Sent from my SCH-I545 using Tapatalk
April 23, 2014, 11:53:53 am
Re: Harbor freight compression tester?
April 23, 2014, 11:53:53 am »
Most folks say it tends to read a bit low. The real purpose of a compression tester though is to track changes over time and to identify differences from one cylinder to the next. It'll do those things just fine.
April 23, 2014, 12:59:09 pm
Moderator
4549
April 23, 2014, 12:59:09 pm »
They make several kits so be careful in comparison shopping. I have one and it seems to do fine. Like is said, for comparing across the engine and approximate values only.
April 23, 2014, 01:25:13 pm
Smoker
Re:
April 23, 2014, 01:25:13 pm »
Thanks. That was my thought as well... that a compression tester is meant to show major problems, not extremely precise numbers. I think I'll grab one.
April 23, 2014, 10:27:00 pm
TimpanogosSlim
Pretty dumb for a smart guy
April 23, 2014, 10:27:00 pm »
indeed, it seems ok but test it against pressure gauge you trust perhaps?
April 24, 2014, 11:12:16 am
Wayland
April 24, 2014, 11:12:16 am »
I bought one off ebay, but as far as I know, it's the same as the one HF sells. I have used it several times, and while I have nothing to compare it to, the results have always seemed believable. It seems like a decent quality tool.
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
April 24, 2014, 11:25:38 am
April 24, 2014, 11:25:38 am »
My understanding is that the reason they tend to read low is due to the volume inside the adapters rather than any issue with the gauge itself. 23:1 compression means the volume of the adapter itself is fairly substantial so it will cause a lower "apparent" reading than a different gauge with less space inside the fittings.
General Information
General
