Author Topic: over torque head bolts  (Read 4946 times)
March 15, 2014, 01:20:14 pm
somolovitch3
  • 290
« on: March 15, 2014, 01:20:14 pm »
About says it all. :'( Read the numbers, did it foot pounds instead of Nm's.
How bad am I off?  >:(
Thank you for your time and effert.
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #1March 15, 2014, 01:56:37 pm
Re: over torque head bolts
« Reply #1 on: March 15, 2014, 01:56:37 pm »
stock bolts?
stretch or non?
If they are stretchy and didn't snap, probably fine
Reply #2March 15, 2014, 02:30:58 pm
somolovitch3
  • 290
« Reply #2 on: March 15, 2014, 02:30:58 pm »
12 pt strech. I figure I am 1/4 turn over what you would be if they were 6 pt. 15 ft#s past (before the two 1/4 turns) what they were supposed to be.This is officially in EggSuck teritory.
« Last Edit: March 15, 2014, 03:05:35 pm by somolovitch3 »
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #3March 15, 2014, 07:19:39 pm
Spokerider
  • 195
« Reply #3 on: March 15, 2014, 07:19:39 pm »
Thought I read a post on here about stretch bolts [ in general ] and the correct torque of them, being close to the point of metal failure.
If it were me, I'd eat the cost and buy / install new bolts for piece of mind.
Reply #4March 15, 2014, 07:38:04 pm
« Reply #4 on: March 15, 2014, 07:38:04 pm »
You can pretty much tell if they fail.
 I had a whole bunch fail while tightening,but all the ones  which survived   installation were fine thereafter.  the ones that broke, extract and stuff in a new one, no big deal.
Maybe it would be a concern in an ultra performance motor, but then you probably would not want  stretch bolts anyway.
Reply #5March 16, 2014, 03:52:12 am
somolovitch3
  • 290
« Reply #5 on: March 16, 2014, 03:52:12 am »
Okay, Odd thought :o...If I replace each bolt one at a time, think I could save the head gasket, or will I be risking warping the head?
I think I am PAST EggSuck teritory!
Again, Thank you all for your time and effert.
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #6March 16, 2014, 07:24:45 am
« Reply #6 on: March 16, 2014, 07:24:45 am »
I wouldn't worry too much about it.
Once the bolts reach yield point, they don't add much more pressure and the extra 1/4 turn shouldn't be close to the fail point.
Reply #7March 16, 2014, 08:18:50 am
« Reply #7 on: March 16, 2014, 08:18:50 am »
It's reasonably common for people to swap to head studs one at a time to save the headgasket. You should be fine doing it.
