Author Topic: alt light at idle  (Read 5323 times)
January 05, 2014, 08:28:06 am
bbob203
  • 1789
alt light at idle
« on: January 05, 2014, 08:28:06 am »
When my MK2 is idling the charging system dashlight is on. Sometimes when I come to a stop and it will take a second but it will come on then I'll drive off and it goes away. The regulator is newish and showed some corrosion so i cleaned that off god and put dielectric bulb grease on it didn't change anything..
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1January 05, 2014, 09:04:45 am
air-cooled or diesel
Re: alt light at idle
« Reply #1 on: January 05, 2014, 09:04:45 am »
a glowing light at idle is normal(at night), take a multi-meter and check charge voltage at idle.
if light is brighter than glowing check battery, connections/cables(and grounds), check voltage of battery, key off, and voltage at idle and at higher revs(around 2000rpm). check voltage drop and at grounds too.
could be a faulty regulator.?
Reply #2January 07, 2014, 11:53:53 am
  • 2926
« Reply #2 on: January 07, 2014, 11:53:53 am »
 Does it still do it with your headlights on,.. with a load?
Reply #3January 07, 2014, 12:01:34 pm
bbob203
  • 1789
« Reply #3 on: January 07, 2014, 12:01:34 pm »
less bright and the brights even less.
03 Jetta wagon TDi
Reply #4January 07, 2014, 12:23:01 pm
« Reply #4 on: January 07, 2014, 12:23:01 pm »
When my alt light flickers at idle it only takes a small load, like opening the door or touching the brakes to make it go out.
Reply #5January 07, 2014, 03:58:02 pm
bbob203
  • 1789
« Reply #5 on: January 07, 2014, 03:58:02 pm »
The exciter wire female spade terminal was about disconnected from the exciter wire 1 or 2 braids still making contact with the spade coupled with a super rusty D+ terminal on the alt new female space cleaned of the rust and some di electric grease and its good to go no more dim light. ;D
03 Jetta wagon TDi
Reply #6January 07, 2014, 09:30:51 pm
8v-of-fury!
« Reply #6 on: January 07, 2014, 09:30:51 pm »
I have a dim light with perfect connections.. only with no load on the alt though.
