Author Topic: Fittings for custom TDi/AAZ oil drain.  (Read 4093 times)
November 18, 2013, 04:09:11 am
bbob203
  • 1789
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1November 18, 2013, 05:08:16 am
Re: Fittings for custom TDi/AAZ oil drain.
« Reply #1 on: November 18, 2013, 05:08:16 am »
wonder if that is the same as the IP banjo?
Reply #2November 18, 2013, 05:45:59 am
« Reply #2 on: November 18, 2013, 05:45:59 am »
IP banjo is the same as the oil feed line on AAZ/AHU/1Z engines.
Reply #3November 20, 2013, 05:37:08 am
stewardc
« Reply #3 on: November 20, 2013, 05:37:08 am »
Why use a banjo at all? I converted mine to AN fittings. MUCH nicer.
Reply #4November 20, 2013, 05:55:55 am
bbob203
  • 1789
« Reply #4 on: November 20, 2013, 05:55:55 am »
I was thinking this may work for the DRAIN banjo fitting on the back of the block but i think its to small.
03 Jetta wagon TDi
Reply #5November 20, 2013, 06:54:23 am
stewardc
« Reply #5 on: November 20, 2013, 06:54:23 am »
Once again, why use a banjo on the drain??? Use an AN hose.
Reply #6November 25, 2013, 04:01:54 am
stewardc
« Reply #6 on: November 25, 2013, 04:01:54 am »
Here are the parts you need.
