Author Topic: Oh the noise noise Noise!!  (Read 4390 times)
October 23, 2013, 06:38:20 pm
srgtlord
  • 797
« on: October 23, 2013, 06:38:20 pm »
Ok I finally have my 85 golf running for the first time and it run great except there is unbearable low decibal noise at idle. Should I put a resonator on the exhaust? Would changing the pump timing change anything?
Reply #1October 23, 2013, 06:55:15 pm
Re: Oh the noise noise Noise!!
« Reply #1 on: October 23, 2013, 06:55:15 pm »
Low decibel or low pitch?
I presume low pitch, because low volume (decibel) usually isn't a problem.
Where does the sound seem to originate?
Reply #2October 23, 2013, 07:07:20 pm
srgtlord
  • 797
« Reply #2 on: October 23, 2013, 07:07:20 pm »
Im not exactly sure, as its only an issue while sitting in the car....
Reply #3October 23, 2013, 08:24:03 pm
« Reply #3 on: October 23, 2013, 08:24:03 pm »
Pipes not rubbing on the frame somewhere are they?  This may only happen when you sit in the car so weigh it down some and get under it to see and listen.  Feel any vibration in the floor?  How about the hangers? Are they solid or is it rubber mounted to isolate the engine vibration from the body?
Just some of the things I dealt with last weekend when my exhaust shifted after going over some incredible rough spots on our well maintained streets.  Winky Wink.   ;)
Reply #4October 24, 2013, 02:20:31 pm
mzak88
  • 31
« Reply #4 on: October 24, 2013, 02:20:31 pm »
Jeez I run straight pipe - from turbo to bumper. Never really a bother. Only noticeable under heavy throttle application.
97 IDI Jetta, O2A CTN,0.658 5th, 1.6 boost pin, TDI IC, 2.0 brakes, some tuning.
Reply #5October 27, 2013, 08:00:41 pm
srgtlord
  • 797
« Reply #5 on: October 27, 2013, 08:00:41 pm »
Problem solved with a sawz-all. The carppy u-joint muffler clamps were hitting part of the frame. After 5 minutes they certainly were not anymore :)
Reply #6October 27, 2013, 09:01:32 pm
« Reply #6 on: October 27, 2013, 09:01:32 pm »
Maybe not exactly the pipes hitting the frame but real close now wasn't it.  I got mine tweaked again this weekend.  Now I get a vibe when I back up on the hill I live on.  Maybe time to go get a bend adjusted on it so it fits with a little more slack.
Reply #7October 27, 2013, 10:31:15 pm
« Reply #7 on: October 27, 2013, 10:31:15 pm »
Or a meaner motor mount.
Reply #8October 28, 2013, 11:38:38 am
« Reply #8 on: October 28, 2013, 11:38:38 am »
Those are all new as well.  or at least less than a year old.
