Author Topic: Gasser oil pan on 1.6 n/a?  (Read 3326 times)
August 09, 2013, 11:07:50 am
jlpst94
  • 72
« on: August 09, 2013, 11:07:50 am »
Anyone know if a gasser oil pain will bolt on a 1.6 diesel block?
Reply #1August 09, 2013, 11:10:10 am
bbob203
  • 1789
Re: Gasser oil pan on 1.6 n/a?
« Reply #1 on: August 09, 2013, 11:10:10 am »
yes it will work if its a transversal motor.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2August 09, 2013, 11:46:00 am
  • 5104
« Reply #2 on: August 09, 2013, 11:46:00 am »
Theyre the same only difference could be early low volume pan
Reply #3August 09, 2013, 11:46:20 am
jlpst94
  • 72
« Reply #3 on: August 09, 2013, 11:46:20 am »
Perfect,  Thanks
Reply #4August 09, 2013, 11:48:13 am
jlpst94
  • 72
« Reply #4 on: August 09, 2013, 11:48:13 am »
Broke a turbo return line on an ecodiesel and need to make it an N/A until I come up with a new turbo setup.
Reply #5August 09, 2013, 04:54:58 pm
CrazyAndy
  • 739
« Reply #5 on: August 09, 2013, 04:54:58 pm »
Have you thought about re-welding the oil return?
Reply #6August 09, 2013, 09:30:48 pm
« Reply #6 on: August 09, 2013, 09:30:48 pm »
The return? Just cut the bad piece out and add a rubber oil rated line in with clamps. No pressure there.
Reply #7August 10, 2013, 06:33:47 pm
jlpst94
  • 72
« Reply #7 on: August 10, 2013, 06:33:47 pm »
I'm gonna replace the eco turbo and pump.  The oil return is different on the TD pumps so I'm just running it as a N/A until I get all of the parts
Sent from my iPad using Tapatalk HD
Reply #8August 10, 2013, 06:36:29 pm
jlpst94
  • 72
« Reply #8 on: August 10, 2013, 06:36:29 pm »
What oil line do you guys know of that will take that kind of heat?   If I could just clamp something on to replace the braided section I probably would do that rather than take the time to remove everything and weld in a new piece.
Reply #9August 10, 2013, 08:05:27 pm
« Reply #9 on: August 10, 2013, 08:05:27 pm »
I am pretty sure I have seen just the rubber hose.. like used on oil coolers. 300psi stuff.
Reply #10August 10, 2013, 09:10:28 pm
« Reply #10 on: August 10, 2013, 09:10:28 pm »
300 psi hose for power steering at auto Bones is something close to $3/foot.  I used it on my remote oil filter and seems fine with the heat.  does not get soft and droop.
Reply #11August 22, 2013, 09:01:22 am
jlpst94
  • 72
« Reply #11 on: August 22, 2013, 09:01:22 am »
The gasser oil pan bottoms out on the dipstick tube.  F$&# I guess I'll try to cap off my turbo oil pan and use it.
Reply #12August 22, 2013, 10:18:51 am
  • 5104
« Reply #12 on: August 22, 2013, 10:18:51 am »
must be an older pan?
