Author Topic: AAZ woes....  (Read 2928 times)
June 04, 2013, 01:40:38 pm
stewardc
AAZ woes....
« on: June 04, 2013, 01:40:38 pm »
Every since I got the truck out of storage this spring, it's started hard, particularly when warm.I get a LOT od fuel smoke, and a rough idle. Seems to pull well, and no odd noises...runs cool...all else OK, but cranks a long time before it catched and belches a cloud of black/blue smoke that smells like you rubbed raw fuel on your nose.
I'm thinking injectors...any ideas?
Reply #1June 04, 2013, 02:31:49 pm
Re: AAZ woes....
« Reply #1 on: June 04, 2013, 02:31:49 pm »
Any air in the lines while cranking/right after startup?
Reply #2June 04, 2013, 05:21:23 pm
stewardc
Re: AAZ woes....
« Reply #2 on: June 04, 2013, 05:21:23 pm »
None that I can see.
Reply #3June 09, 2013, 12:50:59 pm
CrazyAndy
  • 739
Re: AAZ woes....
« Reply #3 on: June 09, 2013, 12:50:59 pm »
Do you have a lift pump?  Is your pump timing off?
Reply #4June 10, 2013, 11:49:36 am
stewardc
Re: AAZ woes....
« Reply #4 on: June 10, 2013, 11:49:36 am »
No lift pump, but I'll be replacing the water pump and timing belt within the next 2 weeks, so we'll see how everything looks then.
Reply #5September 02, 2013, 09:45:54 am
stewardc
Re: AAZ woes....
« Reply #5 on: September 02, 2013, 09:45:54 am »
Update. We took some things apart and found something had punched 2 holes in the timing belt, and loosened the bottom pulley. That had "worked" some and allowed the timing to go off. All fixed and back to normal now.
Reply #6September 02, 2013, 09:55:39 am
Gizmoman
  • 1301
Re: AAZ woes....
« Reply #6 on: September 02, 2013, 09:55:39 am »
Interesting - good save.
Are you running a belt cover?
What sprocket do you have - the TDI "D" style or the tiny key style?
Reply #7September 02, 2013, 10:16:36 am
stewardc
Re: AAZ woes....
« Reply #7 on: September 02, 2013, 10:16:36 am »
Yes, I am running a belt cover and a TDI pulley. We are still baffled by the problem, but the cure was OK.
Reply #8September 02, 2013, 03:54:48 pm
CrazyAndy
  • 739
Re: AAZ woes....
« Reply #8 on: September 02, 2013, 03:54:48 pm »
So the crank bolt is holding strong?  You remember to add some loctite for good measure?
Yeah, it's always a good idea to check crevices and such after getting a car out of storage.  Critters like to hide and store things for the winter, and it sounds like one found an ideal hidey hole in your timing belt cover.
Reply #9September 02, 2013, 06:21:18 pm
stewardc
Re: AAZ woes....
« Reply #9 on: September 02, 2013, 06:21:18 pm »
I do suspect that the builder (not me) reused the stretch bolt and used too little locktite. However, that being said, the repair is flawless. Now, where can one get good rodent traps ???
Reply #10September 02, 2013, 07:27:09 pm
Re: AAZ woes....
« Reply #10 on: September 02, 2013, 07:27:09 pm »
Rodents really like peanuts,  Poison peanuts might work.
