Author Topic: Low idle alt light on.  (Read 6015 times)
March 29, 2013, 06:04:05 pm
bbob203
  • 1789
« on: March 29, 2013, 06:04:05 pm »
I've got my idle down lower than I have ever had it about 750 rpm and to my surprise it's very quite and smooth almost no vibration not sure what this means but I dig it. Anyhow at calm idle no load on alt the cluster light is dimly lit and somewhat flickery but if I turn on the heater to high or the lights it goes off or if I artificially raise it by pressing my foot on the pedal and giving it a bit of go to bring it to 1000 rpm. I lowered my idle inadvertently when I turned down my max fuel screw tonite to see if I can't raise my fuel economy and clean up my smokey exhaust. Expecting to have to raise it back up I realized how nice it was idling and left it alone. Thoughts?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1March 29, 2013, 06:12:52 pm
Re: Re: Low idle alt light on.
« Reply #1 on: March 29, 2013, 06:12:52 pm »
Sounds about normal! It probably won't cause you any issues unless you are idling for hours at a time.
Sent from my HTC One X using Tapatalk 2
Reply #2March 29, 2013, 06:35:22 pm
« Reply #2 on: March 29, 2013, 06:35:22 pm »
When the idle is down and the light is on, check the charging voltage. I have seen this before. Interested to see if the voltage is down when the light is on or not.
Reply #3March 29, 2013, 06:35:44 pm
« Reply #3 on: March 29, 2013, 06:35:44 pm »
normal... step on brakes/put any load on charging system and will go out..
Reply #4March 29, 2013, 08:34:59 pm
« Reply #4 on: March 29, 2013, 08:34:59 pm »
Mine does that all the time after a fairly long run and charged battery.  If you can stand it at night, while waiting for a light to change leave it alone.  I need to bump my idle up from where you are now or I have trouble getting started on steep hills.  Like the one I live on.  Down only.
Reply #5March 29, 2013, 10:13:07 pm
« Reply #5 on: March 29, 2013, 10:13:07 pm »
Raise your idle. There's no reason for it to be that low.
Your fuel savings will be negligible but your alternator won't charge, your oil pressure will be lower and your water pump won't circulate coolant as efficiently, so it actually might run hot.
Reply #6March 29, 2013, 11:22:42 pm
bbob203
  • 1789
« Reply #6 on: March 29, 2013, 11:22:42 pm »
hmm thanks gentlemen. Its so dang quite though like I'm not even driving a diesel. this was occuring after some hard fast cruising through the city so the battery was good and juiced up.
03 Jetta wagon TDi
Reply #7April 01, 2013, 09:07:49 am
« Reply #7 on: April 01, 2013, 09:07:49 am »
The alt light is flickering because the alt is just baaarely putting out enough juice to equal the battery voltage.  That light comes on when the battery voltage is greater than the alternator voltage (like when the alternator is non-functional for instance).  So a fully charged battery will actually make it flicker more than a low one.
If you really like your idle there and the light really causes you concern, you could always try finding a smaller alternator pulley.  Some of the factory alternator pulleys are actually adjustable - you can add a washer in the middle to spread the two halves further apart resulting in a smaller effective pulley size.  How much adjustment is available depends on where you are at now though.  If you have a tach it'll mess with the accuracy a bit too.
Reply #8April 01, 2013, 12:18:22 pm
« Reply #8 on: April 01, 2013, 12:18:22 pm »
10w lightbulb...... all it needs is something to use power... brake lights = 2 bulbs.. makes it go out... some type of voltage load...
why my gas car no do this... ahhh fuel pump/coil...
Reply #9April 01, 2013, 06:06:27 pm
bbob203
  • 1789
« Reply #9 on: April 01, 2013, 06:06:27 pm »
I actually do have a solid  pulley on the bench vs the split one on the car was wondering wich one was better to run..
03 Jetta wagon TDi
Reply #10April 01, 2013, 06:37:50 pm
« Reply #10 on: April 01, 2013, 06:37:50 pm »
So on our diesels, its a poor mans "battery is charged" light ahha
Reply #11April 01, 2013, 09:35:37 pm
nwcali6
  • 69
« Reply #11 on: April 01, 2013, 09:35:37 pm »
  I like the sound of my diesel..clickity clack sounds like money in my bank account versus the gas guzzling gassers..
  I agree about the low idle and oil pressure, but if its your thing...
Reply #12April 02, 2013, 05:26:45 am
Rising
  • 385
« Reply #12 on: April 02, 2013, 05:26:45 am »
Mine used to do this as my alternator was on its way out. It would do it only at stop lights and such and only dimly. And then eventually it stopped charging my battery completely and died.
The new 90 amp I swapped in has no signs of that at all. Light comes on in the morning and goes out after first rev. Never to return.
Just my personal experience but mine didn't have anything to do with the idle speed...
Sent from my ThunderBolt using Tapatalk 2
'84 Rabbit Diesel- 1.6D Stock
Reply #13April 02, 2013, 09:22:24 pm
« Reply #13 on: April 02, 2013, 09:22:24 pm »
ok.. if applying the brakes does not turn it off.. yes the alt is going bad or the fusebox is wet.. but hitting brakes/applying any load makes it go off.. its normal..
