Author Topic: Smoke stacks!  (Read 12667 times)
February 15, 2013, 01:18:14 pm
Sierra94
  • 123
    Dieselsmoke in every stroke... M-Tdi Mazda!!
    • http://www.garaget.org/sierra94
Smoke stacks!
« on: February 15, 2013, 01:18:14 pm »
Someone on the forum told me to put stacks on my truck, so when I found a box full of leftover stainless bends etc at work I started building a set last night.
But I need some opinions. Should I keep or remove them? I havent made the hole throught the bed yet. And the stacks need a good polish to get shiny.
And some work in progress pics:
« Last Edit: February 15, 2013, 01:25:19 pm by Sierra94 »
<-- My M-tdi Mazda B-1800 and my other cars
Reply #1February 15, 2013, 01:33:48 pm
homerj1
  • 433
Re: Smoke stacks!
« Reply #1 on: February 15, 2013, 01:33:48 pm »
Pretty neat idea!
How about putting these on top?
Reply #2February 15, 2013, 01:39:23 pm
justiz00
  • 54
Re: Smoke stacks!
« Reply #2 on: February 15, 2013, 01:39:23 pm »
Looks great, I am not partial to symmetry so I would prefer to have a single. Not necessarily a 7" like the one I put on my dad’s truck for his build. The straight out of the bed with no turns is what I would run if it were mine. If I had a diesel cabby it would have one (with no top).
Reply #3February 15, 2013, 02:17:41 pm
homerj1
  • 433
Re: Smoke stacks!
« Reply #3 on: February 15, 2013, 02:17:41 pm »
Are there any performance gains? One stack  pipe vs two vs straight 2.25 inch pipe all the way back
If not, I'd think it would basically aesthetics?
Reply #4February 15, 2013, 02:29:21 pm
Sierra94
  • 123
Re: Smoke stacks!
« Reply #4 on: February 15, 2013, 02:29:21 pm »
I like 2 more than one. And I already have 3 inch straight from turbo and back. The stacks are 3 to 3.5 inch pipe. So it wont make any gains.
Reply #5February 15, 2013, 02:57:39 pm
Re: Smoke stacks!
« Reply #5 on: February 15, 2013, 02:57:39 pm »
You can reduce drone if  one leg is a half wave longer.
Reply #6February 15, 2013, 03:39:40 pm
Re: Smoke stacks!
« Reply #6 on: February 15, 2013, 03:39:40 pm »
huh,, learn something new every day.
I just personally do not like seeing single stacks on dual exhaust engines or dual stacks on single exhaust engines.
IE. Two stacks on a Cummins, or single stack on Duramax or PowerStroke.
Reply #7February 15, 2013, 07:10:07 pm
Re: Smoke stacks!
« Reply #7 on: February 15, 2013, 07:10:07 pm »
Yes! Stacks. Must have.  Perhaps right behind the drivers door.
Reply #8February 15, 2013, 07:10:44 pm
Re: Smoke stacks!
« Reply #8 on: February 15, 2013, 07:10:44 pm »
I sense sarcasm....
Reply #9February 15, 2013, 07:13:16 pm
Re: Smoke stacks!
« Reply #9 on: February 15, 2013, 07:13:16 pm »
Sarcasm? No! It's cool.
Reply #10February 17, 2013, 05:57:45 am
dodger21
  • 97
Re: Smoke stacks!
« Reply #10 on: February 17, 2013, 05:57:45 am »
The drone won't be that bad since the exit is just above the cab. Any lower and you will tear them out.
1985 Golf 1.6NA with a 5spd
Reply #11February 17, 2013, 08:36:57 am
Sierra94
  • 123
Re: Smoke stacks!
« Reply #11 on: February 17, 2013, 08:36:57 am »
I made some changes today before grinding/sanding the welds down. I narrowed the connecting pipe between the stacks 2 inches on each side to make the stacks follow the outer line of the cab instead of making it look so "square" as they did before. And they are gonna get one inch higher from the roof when finally mounted in their brackets.
Reply #12February 17, 2013, 09:54:49 am
Re: Smoke stacks!
« Reply #12 on: February 17, 2013, 09:54:49 am »
I dig it man, gonna be awesome.
Reply #13February 17, 2013, 10:36:02 am
Sierra94
  • 123
Re: Smoke stacks!
« Reply #13 on: February 17, 2013, 10:36:02 am »
Thanks!  ;D
Reply #14February 17, 2013, 12:33:14 pm
Re: Smoke stacks!
« Reply #14 on: February 17, 2013, 12:33:14 pm »
Plastic Zip ties?   My exhaust gets too hot for that to stay secured.  Tell me you have thin cables planned for the final look and feel?  Simple bike cable with an overlapping smash aluminum oval might be the ticket.
