Author Topic: Need diagram for rear brake drum  (Read 6961 times)
January 03, 2013, 03:58:48 pm
tyb525
  • 183
« on: January 03, 2013, 03:58:48 pm »
I put new handbrake cables and hooked them up inside the rear drums, but I seem to be missing a part inside the drum. There's an arm the cable attaches to, but it just pivots back and forth and doesn't seem to engage anything inside the drum.
Does anyone know of a good diagram to see what I'm missing? The ones in the bentley aren't clear enough for me to see what I'm missing.
2004 Golf BEW, '81 1.6 NA rabbit (soon to be parted out)
Reply #1January 03, 2013, 04:33:36 pm
Re: Need diagram for rear brake drum
« Reply #1 on: January 03, 2013, 04:33:36 pm »
The arm it pulls on is part of the brake shoe, kind of hard for it to be missing. Also the bar between the shoes couldnt be missing and have it go together either.
The lever you pull doesn't engage anything it pushes the top of the shoe out. Take a closer look at its motion, you are likely just over looking it.
Reply #2January 03, 2013, 04:36:29 pm
« Reply #2 on: January 03, 2013, 04:36:29 pm »
Google.ca is a marvelous invention ;) This took me 0.03 seconds to find.
The parking brake arm pushes on the side of the push rod. Thus pushing out the top of the shoe the arm is on.
Reply #3January 03, 2013, 04:51:19 pm
tyb525
  • 183
« Reply #3 on: January 03, 2013, 04:51:19 pm »
The cables are hooked up to the parking brake arm. I know the rear drums work with the regular breaks. I could flop the parking brake arm left and right and it didn't seem to be connected to anything, just hanging there?
Sorry for the newb question, I'll go look at it again. Maybe I don't have the cables adjusted far enough at the lever.
Reply #4January 03, 2013, 05:43:18 pm
« Reply #4 on: January 03, 2013, 05:43:18 pm »
They're riveted to the top, so if its riveted there, its gotta work. They wouldn't go together at all if it were any other way. If its bolted up and works with brake pedal, then its proper. Adjustment is likely necessary.
Reply #5January 03, 2013, 06:35:17 pm
« Reply #5 on: January 03, 2013, 06:35:17 pm »
Is the adjuster wedge adjusted?
Reply #6January 03, 2013, 07:31:02 pm
tyb525
  • 183
« Reply #6 on: January 03, 2013, 07:31:02 pm »
I guess I need to double check everything and make sure it matches up to that diagram.
Reply #7January 05, 2013, 10:20:58 am
smutts
  • 720
    ClackClackClackClackClack
« Reply #7 on: January 05, 2013, 10:20:58 am »
My sympathies, It's a horrible shagging mess of a design, at least to look at, but it does work pretty well once you get your head around it.
Just a little threadjack, whats the best thing to put on the adjuster "wedge" to stop it sticking, or rusting in place? ???
Reply #8January 05, 2013, 11:55:37 am
« Reply #8 on: January 05, 2013, 11:55:37 am »
wire brush so the side teeth clean... antiseize is what i use.... but gotta clean them teeth or the build up lets it slide to easy...
