Author Topic: injector removal problem when car has N/A pump?  (Read 2666 times)
November 14, 2012, 11:21:37 am
derekp
  • 94
« on: November 14, 2012, 11:21:37 am »
I put an N/A pump on my eco 92 jetta a while back.
Head gasket woes causing me to remove the head - I wanted to do compression test before pulling head to make sure my only issue was the oil leaking out of front side of head.
I discovered I could not put my socket on #2 cyl injector - the aneroid (space ship) on the NA pump is in the way
So - how have any of you dealt with this? I'm not sure that I could even get a box end wrench on that thing even with the lines off the car.
(life must move on - I pulled the head without doing my comp test - oh well....)
The fleet
92 eco diesel (my driver turned project)
94 suburban (mine)
69 Chevelle 327 w/hillborn - resting nicely
89 Jetta coupe (sons 16v ABA head swap w/turbo and megasquirt - not run yet)
2000 jetta (other sons)
98 jetta (daughters)
2001 jetta tdi (girlfriends)
03 subaru outback (girlfrie
Reply #1November 14, 2012, 11:38:42 am
Re: injector removal problem when car has N/A pump?
« Reply #1 on: November 14, 2012, 11:38:42 am »
You could have tried loosening the pump and pulling it all the way away from the engine. Not sure if it would have been enough or not though.
Reply #2November 14, 2012, 04:26:41 pm
Re: Re: injector removal problem when car has N/A pump?
« Reply #2 on: November 14, 2012, 04:26:41 pm »
On mine I can just slip the socket over the injector and THEN connect the extension. No way I can get it on with the extension attached due to interference with my LDA.
Sent from my HTC One X using Tapatalk 2
Reply #3November 14, 2012, 04:50:00 pm
audilvr
« Reply #3 on: November 14, 2012, 04:50:00 pm »
the socket we use at the shop i work at is ground to a taper to fit.
Reply #4November 14, 2012, 05:26:48 pm
derekp
  • 94
« Reply #4 on: November 14, 2012, 05:26:48 pm »
can you guys tell me - 3/8 or 1/2 inch drive socket and what the overall length of the socket you use?
Appreciate it - I only have 1/2 inch drive socket no way will it fit at all.
thanks.
The fleet
94 suburban (mine)
Reply #5November 14, 2012, 08:33:47 pm
« Reply #5 on: November 14, 2012, 08:33:47 pm »
I have one car with the turbo version (LDA) and one with the altitude version (ADA). (The other cars have the lower IP covers.)
I use a MiT 1/2" drive deep impact socket. The socket is probably ~80MM tall and 34mm wide. It just barely fits in the injector-well .
I mark the pump position and turn the top as far from the valve-cover as it will go.
Reply #6November 14, 2012, 08:34:47 pm
« Reply #6 on: November 14, 2012, 08:34:47 pm »
Get an adapter that goes from 3/8ths to 1/2 inch and use the 3/8th extension.  Adapters go both ways.  I use them all the time but mostly to reduce from larger size but on occasion it helps to go the other way.  As in this case.
Reply #7November 14, 2012, 09:08:48 pm
92EcoDiesel Jetta
« Reply #7 on: November 14, 2012, 09:08:48 pm »
Impact sockets are thicker wall so don't use it if space is tight. (ask me how I know) Since getting a 12 point 27 mm deep socket that's much thinner wall than the impact (from Lowes) no more clearance isaues.
