Hi all,
1.6 na, bought her about a year ago, lots of little projects, new timing belt about 4 months ago. Car had a ton of blowby when I bought it, some compression loss is certainly to blame for having to crank for several seconds usually before she lights.
I always kind of assumed I might have a bad glow plug, and the car became noticeably more difficult to start a few days ago (and it's still warm in the pacific nw.) so im thinking, sweet, another plug just went, nice easy job to get her starting right up...bought four new glow plugs and put them in the other day, and tested the old ones afterward. Much to my horror, the old ones all tested good (.9 ohms. +\- about 0.2)
My injector bleed off/return hoses were getting gooey from running biodiesel, and I haven't had a chance to pick up moe fuel line yet, so I won't be able to start the engine until tomorrow, but i cannot reasonably expect any change due to the new glow plugs.
Problem is, I want to drive the car this winter but if starting is just barely difficult in 60-70 degree weather, I don't think ill be able to light her off at all in December.
I plan to load test the battery when I get a chance. Maybe that's part of the prob. Perhaps the injectors aren't spraying a good pattern, I could take them out and down to a shop if you guys think thats worth it. I already know the engine surely must have less than ideal compression although I've never tested.
What else do you guys think I should look into, short of a quick and dirty in frame rebuild ( more like get in, replace piston rings and get out fast)?
The engine really runs beautifully once she gets going. I would love to keep driving the car but it might be a real problem this winter. Block/coolant heaters aren't much of an option since I live in an apt and park on the street.
Thanks in advance fellows. I appreciate your time!
Ted
