Author Topic: Lets talk Vent windows  (Read 5418 times)
August 26, 2012, 12:39:15 pm
monomer
  • 414
« on: August 26, 2012, 12:39:15 pm »
My main gripe with my Mk1 right now.
The Vent window latches have fallen off. I had them reglued when the windshield was replace, neither took.
I've got a set from a mk1 gti, with bolt in hardware. Do I need to switch the entire frame, or can I get away with just the tabs and window?
-1983 Rabbit LX 1.6/1.9 VNT build
Michigan Volkswagen Enthusiasts
www.michiganvw.org
Reply #1August 26, 2012, 02:42:07 pm
Re: Lets talk Vent windows
« Reply #1 on: August 26, 2012, 02:42:07 pm »
entire frame
Reply #2August 26, 2012, 03:50:45 pm
monomer
  • 414
« Reply #2 on: August 26, 2012, 03:50:45 pm »
entire frame
Before I tear into it.
Whats required?
www.michiganvw.org
Reply #3August 30, 2012, 04:05:15 am
rs899
  • 647
« Reply #3 on: August 30, 2012, 04:05:15 am »
IIRC when I removed a set on a Cabriolet, you need to remove the main side glass, all the window channel and unbolt the front window track which carries the vent window.  Fairly involved.
Reply #4August 30, 2012, 12:30:44 pm
« Reply #4 on: August 30, 2012, 12:30:44 pm »
Does this help show you what you might be getting into?
http://www.vwdiesel.net/forum/index.php?topic=30307.0
Can answer specifics once you see these and have an idea of what we have to go through to get a decent wing vent.  I still have to do this on the other side befor it starts raining or just leave it sealed up as it is now.
DAS
Reply #5November 24, 2012, 12:36:25 pm
wolf_walker
  • 1205
« Reply #5 on: November 24, 2012, 12:36:25 pm »
I've often wondered if one could not drill the plates and glass to use tiny machine bolts.  Haven't ever had a spare set I could risk sacrifice to try it, but it seems plausible.
Mentat Text Two
Reply #6November 24, 2012, 03:31:14 pm
monomer
  • 414
« Reply #6 on: November 24, 2012, 03:31:14 pm »
It's tempered glass. It'll shatter.
Taping them shut this year. It's to cold to be fighting a door here in MI
www.michiganvw.org
Reply #7November 24, 2012, 07:04:54 pm
wolf_walker
  • 1205
« Reply #7 on: November 24, 2012, 07:04:54 pm »
Crap.  I kept suggesting it around looking for a good reason it can't be done.  Thanks..
Mentat Text Two
Reply #8November 24, 2012, 09:12:39 pm
« Reply #8 on: November 24, 2012, 09:12:39 pm »
It can be done as I have swapped them out in my MK1.  The reason it can't be done now is that you really have to tear the whole thing out of the donor door and then remove all the early model hardware before you can reassemble any measure of it.  I did a door in one day but was taking my time and pictures and enjoying the 65 degree weather and sunshine.  I don't think that is in the near future for anyone in MI right now.
And I used silicone on them the first winter as I got tired of draining the 3 inches of water out of the floorboard every time I had to go to work.  Actually got so tired of it I drilled a couple of holes in the corners to make it happen as the water came in.
I really needed a garage then.  Still do.
Reply #9December 02, 2012, 01:05:39 pm
shorttimer
  • 121
« Reply #9 on: December 02, 2012, 01:05:39 pm »
I always wondered why someone didn't make a one piece replacement kit like the 'Cal look' glass for the bugs. Would eliminate the wing/troubles & look way cooler.
Reply #10December 02, 2012, 03:39:53 pm
CrazyAndy
  • 739
« Reply #10 on: December 02, 2012, 03:39:53 pm »
My '81 westy MK1 came with non-vent corner glass.  Couldn't you swap that in from a comparable model?
Reply #11December 02, 2012, 08:03:47 pm
wolf_walker
  • 1205
« Reply #11 on: December 02, 2012, 08:03:47 pm »
Far as I know that is the easiest option.  I've never had working wing windows in an A1 chassis car, but I have had them in W114 Mercedes and
old Lincolns and a few other things and really, really liked them.  Shame they are such a pain on the Rabbits.
Mentat Text Two
