Author Topic: For all us that turn a wrench. If it were only that quick  (Read 6225 times)
July 11, 2012, 06:12:51 pm
« on: July 11, 2012, 06:12:51 pm »
A friend of mine that thinks I spend too much time rebuilding things mechanical.  He says this clip makes it look super easy.
Might be a guide for some that haven't been there before and would like to see what it might take to take it apart.
And to think I used to own a Triumph at one time.
Enjoy,
http://www.tvkim.com/watch/2121/kims-picks-engine-rebuilds-itself?utm_medium=nl&utm_source=dotd&utm_content=2012-07-10-fifl&utm_campaign=r
Reply #1July 12, 2012, 01:44:09 am
Re: For all us that turn a wrench. If it were only that quick
« Reply #1 on: July 12, 2012, 01:44:09 am »
That thing has more flywheel than my Chevy :(
Reply #2July 12, 2012, 12:05:31 pm
« Reply #2 on: July 12, 2012, 12:05:31 pm »
5x the flywheel, for a 5" clutch...
anyone know what that old pile of iron is?
Reply #3July 12, 2012, 01:04:41 pm
« Reply #3 on: July 12, 2012, 01:04:41 pm »
A go-cart/tractor half breed disguised as a car, AKA Triumph Spitfire.    My brother DDs one with a Nissan dual cam 1.6, and its been a really solid car.
Reply #4July 12, 2012, 01:33:48 pm
« Reply #4 on: July 12, 2012, 01:33:48 pm »
looked like a tractor engine..
Reply #5July 12, 2012, 05:40:48 pm
« Reply #5 on: July 12, 2012, 05:40:48 pm »
Looks like they did it in one full day, sun up to sun down. I mean if you had all the proper tools and the know-how of that particular engine... One day full rebuild? no problem.
Reply #6July 12, 2012, 06:35:19 pm
« Reply #6 on: July 12, 2012, 06:35:19 pm »
Triumph was not all that bad of a car,  Just that it is English and requires a different kind of automotive care.  And I am not talking about doing everything from the rightside either.  To the English it is part of owning a car to add 2 oz of oil here or lubricate this every weekend.  Not the American way.
I actually had the GT6+ Spitfire.  My girl at the time hated it because where can you go in those bucket seats?
Reply #7July 12, 2012, 07:10:57 pm
shwak23
  • 417
    1990 VW Golf TD. Engine Code CY
    • Blackdog Junkyard
Re: Re: For all us that turn a wrench. If it were only that quick
« Reply #7 on: July 12, 2012, 07:10:57 pm »
It says it was done over eleven months.
Sent from my DROID X2
Reply #8July 12, 2012, 07:12:43 pm
« Reply #8 on: July 12, 2012, 07:12:43 pm »
OH WOW.. 11 months?! MAybe the editing was done over 11 months??
Reply #9July 12, 2012, 11:13:09 pm
Syncroincity
  • 727
« Reply #9 on: July 12, 2012, 11:13:09 pm »
Don't forget the Whitworth hardware. I was trying to work on an MG back in the '80s, none of my metric or standard sockets would fit some of the bolts... WTF, over?  ???
Tractor engines is a pretty apt description, these cars are begging for swaps.
Have you guys seen the Honda V-Tec powered classic Minis?
www.superfastminis.com
That is on my short list for future projects.  ;D
Great video, thanks for posting it!!
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
'04 Passat Variant GLS 4Mo 5MT
Reply #10July 13, 2012, 12:32:40 am
« Reply #10 on: July 13, 2012, 12:32:40 am »
screw Vtec.
I got to wad this up a few times, but I surprised a lot of street bikes ;D
Reply #11July 13, 2012, 05:45:07 am
rs899
  • 647
« Reply #11 on: July 13, 2012, 05:45:07 am »
That Spitfire is a UK version, looks to be a MkII from around 1966 or so, yet the engine has an alternator (rather than a generator).  I have a MKIII hanging up on my lift  that I need to get down and use.  I rebuilt the engine and OD gearbox on it years ago (20 now!) and only put 3 K miles on it since.  Fun car , but really frightening to drive now with SUVs running amuk.
If you want to see a tractor engine, that would be the TR3/TR4 ( got one of those , too.  They actually used it in the Ferguson tractor of the period.  Wet sleeve block that can be rebuilt in the field.
« Last Edit: July 13, 2012, 08:01:21 am by rs899 »
Reply #12July 13, 2012, 06:21:18 am
« Reply #12 on: July 13, 2012, 06:21:18 am »
Shaguar
Reply #13July 13, 2012, 01:09:11 pm
« Reply #13 on: July 13, 2012, 01:09:11 pm »
screw Vtec.
DAMN!!!
Reply #14July 14, 2012, 12:28:05 am
billybobf
  • 318
    89 golf 1.8 digi, 1.6 na in pieces in the shop
« Reply #14 on: July 14, 2012, 12:28:05 am »
all machine aspects of rebuilding a motor can be done in a day no problem, if you had all your cleaning components, and new parts ready to go, you could easily disassemble, clean, machine and reassemble in 16hr day.  including new kline valve guides, or if it already has press in valve guides just replacing them, surfacing block and head, grinding valves, boring, honing, align honing, rod prep, crank grind and cam grind if desired/needed and assembly. shoot I honestly think anything over 16hrs worth of labor into a rebuild is kinda LAME, but since most of us dont get to use our time that wisely, it seems like it takes so much longer!
