Author Topic: Need help with IP  (Read 7244 times)
Reply #15July 10, 2012, 12:39:30 pm
mtrans
  • 308
Re: Need help with IP
« Reply #15 on: July 10, 2012, 12:39:30 pm »
 X 2 on blue it`s MUST.
I`ll improve my English
Reply #16July 10, 2012, 01:50:41 pm
« Reply #16 on: July 10, 2012, 01:50:41 pm »
Just need to simulate that charge direction limitation thing with a simple LED  Light Emitting Diode.  I bet you could wire it to the ignition side and get it working without the clutter called the instrument cluster.  Could be a real simple diode in a socket that snaps into the dash.  On with ignition and off when the alternator runs.
What do you think Libby?  Does he need a resistor on the LED to take the 12 VDC as well?  I think so just not sure of the ohm rating.  similar to what is used when folks mod their dash lights using LEDs.
Reply #17July 22, 2012, 09:12:41 pm
erice1984
  • 263
« Reply #17 on: July 22, 2012, 09:12:41 pm »
I used a light bulb from an autometer gauge.   I tried the LED thing once and it didn't work.
1980 Rabbit 1.9TD
Reply #18July 23, 2012, 01:38:47 pm
mtrans
  • 308
« Reply #18 on: July 23, 2012, 01:38:47 pm »
With LED on 12v you need 1.2K resistor,but I only know bulb one.
