Author Topic: Fuel only coming from two Nozzles.  (Read 2734 times)
June 23, 2012, 09:10:45 pm
shwak23
  • 417
    1990 VW Golf TD. Engine Code CY
    • Blackdog Junkyard
« on: June 23, 2012, 09:10:45 pm »
I have this injection pump. It was resealed by some kid I know who had supervision of experienced people but I don't know how much they helped. I have been spinning it over with a drill and I only get fuel out of the bottom two nozzles on the back of the pump... Not the top two? Why?
Reply #1June 24, 2012, 12:06:42 am
damac
  • 531
Re: Fuel only coming from two Nozzles.
« Reply #1 on: June 24, 2012, 12:06:42 am »
Did you push or pull fuel through the pump before turning it over or did you start dry?
1985 turbo diesel jetta
Reply #2June 24, 2012, 08:35:06 am
shwak23
  • 417
    • Blackdog Junkyard
« Reply #2 on: June 24, 2012, 08:35:06 am »
I filled it with fuel using an electric pump coming off the return line.
Reply #3June 24, 2012, 09:25:31 pm
shwak23
  • 417
    • Blackdog Junkyard
« Reply #3 on: June 24, 2012, 09:25:31 pm »
Reply #4June 25, 2012, 08:24:10 am
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: Fuel only coming from two Nozzles.
« Reply #4 on: June 25, 2012, 08:24:10 am »
Could those nozzles be clogged?
Sent from my DROID X2
Reply #5June 25, 2012, 08:47:49 am
« Reply #5 on: June 25, 2012, 08:47:49 am »
I had that happen on a pump that I completely disassembled and reassembled.  With additional cranking it all sorted itself out.  Was the electric pump running the whole time you were spinning the pump?
Reply #6June 25, 2012, 09:33:45 am
shwak23
  • 417
    • Blackdog Junkyard
« Reply #6 on: June 25, 2012, 09:33:45 am »
I don't think it was. I am going to put it back on the car and try just cranking it some more. Maybe she'll work her own kinks out.
Reply #7June 28, 2012, 08:43:33 pm
shwak23
  • 417
    • Blackdog Junkyard
« Reply #7 on: June 28, 2012, 08:43:33 pm »
Fyi excessive cranking and this particular issue solved itself.
