Author Topic: 81 non turbo has no power. Been sitting for six years  (Read 7654 times)
June 06, 2012, 11:53:05 am
Monoaural
  • 13
« on: June 06, 2012, 11:53:05 am »
I just picked up an 81 Caddy. Engine code CR. Previous owner said the owner before him put a new/rebuilt motor in it, and then it sat. With a lot of priming, and a shot of ether, she fired up. Instantly pressurized the coolant system, so retorqued head (has 12pt head bolts, which are gas, I believe). The bolts broke free with ~30ft/lbs, so I feel good about redoing that. Got it running again, (off of fresh diesel in a separate tank). Pump wasnt holding prime, and was leaking from what looks like the timing belt gear. Ran it off ATF, and it stopped spraying diesel everywhere. Decided to run it off its own tank, and run down to the station for new fuel. Runs ok, much quieter than off of the ATF, but no power. No difference between half and full throttle, and I am not sure if it can get to 55mph. I had a 80 with a 1.5 and FF trans that could exceed 80mph(if you were patient.)
Added some diesel clear (about 2oz) to the tank before I filled it up with new stuff. I am assuming the fuel in the tank lines up with when it was non-oped six years ago, but the PO said work was done on it two years ago.
Did just notice that I smashed the return braided line going from the out bolt to the injectors. There was white smoke with the ATF, but I don't see any smoke with the old diesel.
My thoughts: Old diesel doens't have the bang of the new stuff, and it will take a while for the new stuff to get there, but only 50% of the power? Clogged intank filter, which would be bad news, since now I have a full tank. Bad pump timing, since the head wasn't bolted on properly, I doubt they had it timed correctly either.
Reply #1June 06, 2012, 07:53:50 pm
Re: 81 non turbo has no power. Been sitting for six years
« Reply #1 on: June 06, 2012, 07:53:50 pm »
If there was fuel spraying out from behind the pumps timing gear, then the seal and two brass bushing in the pump need replacing. It is easy to replace the seal, but you need to completely take the pump apart. However it will soon leak again after you put the pump back together.. as the brass bushings (which are not easy to replace) will cause the seal to deform in short order.
It needs a rebuild or replacement. The timing belt was likely WAY over tensioned for much of this pumps life at some point.
Reply #2June 06, 2012, 10:24:33 pm
« Reply #2 on: June 06, 2012, 10:24:33 pm »
I would throw on a clear line on the out banjo and see if your seal in front is filling your pump with air.  You may not be getting all the fuel you need to the injectors in or for you to attain that skin peeling off your face speed that this baby is going to make.
Other items might be the position of the accelerator lever to the shaft that it bolts on to.  Did the PO say anything about messing with those levers?
Timing check surely in order.
If you have run ATF  in it did you let it set at all to clean injectors and other internal parts of the pump.
If you have a separate jar, tank or bucket that you can use to measure the amount of flow out of the pump do that at a slight Idle.  1000 RPMs  You should capture about a liter of fuel in a minute.  No make that 14 ounces.  If not then you may need to tap on the pressure regulator on the engine side of the IP.  Process buried in this forum elsewhere.
That is what I would be hitting on first and is more than you probably want to do right now.  I know, you just want to drive it.  When I first saw the picture I thought about the local white Caddy I looked at a couple of weeks ago.  A real project car, needs it all done.  Engine, trans, interior, floorboards, windshield and seats.  To much for me to handle right now.   It was still sitting in the carport where I looked at it so I don't think he was able to unload it.  He didn't want big money for it, just wanted it gone.
Later DAS
Reply #3June 07, 2012, 08:08:32 am
rs899
  • 647
« Reply #3 on: June 07, 2012, 08:08:32 am »
In addition to the obvious fuel issues, verify IP and valve timing and check valve lash.  Based on the head gasket  experience, why assume these are right ?
Reply #4June 07, 2012, 08:27:41 pm
Monoaural
  • 13
« Reply #4 on: June 07, 2012, 08:27:41 pm »
Found an injection pump. Model #068-190-107-A. Would this work for me?
And I will check the timing. Didn't hold the prime over night. Also didn't let the ATF sit, I still have some left, I think i am going to try to let it sit.
More and more I feel like I want to find a turbo motor.
How would I make a clear return?
« Last Edit: June 07, 2012, 08:29:25 pm by Monoaural »
Reply #5June 07, 2012, 08:49:59 pm
« Reply #5 on: June 07, 2012, 08:49:59 pm »
Well to make a clear return line you can either buy a section of clear line that would go from the Out Banjo to just under the fuel filter.  I think 3 feet would do but I just bought 4 tonight of some solid black able to withstand diesel type fuel line.  I have a different set up then your stocker only because of a recent install of a WVO system.  I needed a few more inches and didn't care for a splice so I just went for the full 4 footer.  But I think you could do it with 3.
Another way is to buy one of those inline glass filters that have the replaceable screens in them.  They will probably cost the same as some clear line about 8-9 dollars.  Put clamps on either end of it to keep it from making a mess in the engine bay if it goes to leaking.
Either way this will give you some idea of air coming out of your pump.  I like to run clear lines both in and out at the banjos just so I know if air is coming in from the inlet or a seal in the pump is gone and how much air is it all about.  I just flipped my switches on the WVO system tonight and getting ALL the air out will take some driving time I think.  I have the outlet recirculating the WVO to the inlet and those tiny bubbles are going to be hard to get rid of.  When I purge the WVO out and back down the lines the diesel clears the bubbles out in a hurry.  It has a return to the tank.
Reply #6June 26, 2012, 09:35:24 pm
Monoaural
  • 13
« Reply #6 on: June 26, 2012, 09:35:24 pm »
Let it set two days with ATF in it. It stopped pooling up on the timing gear. Got excited, threw it back on diesel, and let it idle for a bit. It smoothed out, and primed it self, so I took it around the block. By the time I got back in the driveway, completely lost prime, and spraying via the timing gear. There is less than a half inch of deflection on the timing belt. Picked up a smokey 1.5 for a case of beer, so I think I am gonna pull the pump from that one, and throw it on my motor. It looks like it seeps out of the top seal, which is an easier fix, correct? I want to get this thing on the road for the time being, until I find a turbo diesel, or at least a 12mm 1.6 to add a turbo to. If I get antsy, I will turbo the CR motor, and rebuild one of the pumps.
Reply #7June 26, 2012, 09:42:56 pm
« Reply #7 on: June 26, 2012, 09:42:56 pm »
Top seal is easy to fix but getting the bolts loose can be problematic.  I would turbo the 1.5 nothing wrong with that.
Reply #8June 27, 2012, 07:17:31 am
« Reply #8 on: June 27, 2012, 07:17:31 am »
Replacing the shaft seal on your current pump is easier, although more expensive. Like 8v said though, if the bushings are shot you'll need to tear the whole pump down to do it right. Since it was sitting for 6 years the front seal could just be kaput and the bushings fine. How many degrees can you rotate the timing belt easily?
You need to change the timing belt at any rate. Since it is 1) old and 2) soaked in diesel and ATF, it's going to fail, and probably soon.
Reply #9July 03, 2012, 03:58:56 pm
« Reply #9 on: July 03, 2012, 03:58:56 pm »
i tried looking up the pump number you posted, and its not the correct number. nothing comes up with any reference to a bosch VE rotary pump..
it should be a number like this:
0 460 404 120
Reply #10July 03, 2012, 04:30:38 pm
« Reply #10 on: July 03, 2012, 04:30:38 pm »
107 is an early 1.6 na pump
Reply #11July 04, 2012, 08:42:17 am
Monoaural
  • 13
« Reply #11 on: July 04, 2012, 08:42:17 am »
I ended up getting a whole 1.5 for a case of beer, so no worries on the other pump.
My idea is, put the 1.5 pump on my motor, check valve lash, get it on the road. Then, since the 1.6 pump is off, replace the seal, inspect the bushing, and if the 1.5 does leak, swap out and do the same for the 1.5 pump, and have a spare.
Looking again at the 1.5 pump, it may just be a mess from being pulled out, since in banjo wasn't sealed. Timing tools are on there way, hope to have it running this weekend.
Reply #12July 11, 2012, 09:28:23 pm
Monoaural
  • 13
« Reply #12 on: July 11, 2012, 09:28:23 pm »
Pulled the pumps. 1.6 pump has shaft play, so is it new bushing time? Ran out of light, so didn't get the the 1.5 pump on the motor yet.
Reply #13July 11, 2012, 09:30:16 pm
« Reply #13 on: July 11, 2012, 09:30:16 pm »
I would have to agree and next time not so tight on the timing belt.
Reply #14July 29, 2012, 09:16:17 pm
Monoaural
  • 13
« Reply #14 on: July 29, 2012, 09:16:17 pm »
Ok, after having a nightmare getting everything lined up(missed the step on loosening the cam sprocket somehow), got it all together and primed.Added a priming bulb to help with that. Timed it at 1.0 mm. Fired up with a lot of white smoke, and needed full throttle to run. Calmed down after a bit, and idled. Seemed to rev up ok, so took it for a short test drive, after letting it idle to temp(wanted to see if it would lose prime). Didn't make it to the end of my court, didn't want to rev, and started idling real low. Gave the priming bulb a few squeezes, and idle when up, and would rev (in neutral) again. I had it soaking in Diesel 911 for a few days, hoping to get all the old diesel junk out of there. This is with the 1.5 pump on the 1.6. Also, with the bleeder screw open on the filter housing, once the air was out, the bulb got real stiff, time for a new filter?
So, I have a feeling I am gonna need to add a little fuel pump to help the injection pump out, or is there something else I check before I spend money?
