Author Topic: t3 overspeed? with sound clip  (Read 2428 times)
May 12, 2012, 02:02:49 pm
silvertdvw
  • 38
« on: May 12, 2012, 02:02:49 pm »
Im running 24psi with my t3 and it sounds really high piched compared to my k24 at the same boost. Should I turn it down a bit or Is the hich piched scream at full boost somewhat normal for the t3. I am concerned since I lost a fin off the turbine wheel of the k24 because of major boost leaks; the leaks have since been fixed.
Reply #1May 12, 2012, 06:55:49 pm
Re: t3 overspeed? with sound clip
« Reply #1 on: May 12, 2012, 06:55:49 pm »
Why do you choose to run 24psi from the T3? I am just curious as you could probably get the same power with less boost, and less heat.
Reply #2May 13, 2012, 05:42:25 am
  • 5104
« Reply #2 on: May 13, 2012, 05:42:25 am »
That's just what turbos sound like
Reply #3May 13, 2012, 08:03:02 am
silvertdvw
  • 38
« Reply #3 on: May 13, 2012, 08:03:02 am »
i was at 20 for a while just trying a little more and egt's are no higher and it did increase power. Just wanted to make sure since I grenaded the k24 and the t3 has a higher piched whine to it.
Reply #4May 13, 2012, 07:17:37 pm
  • 5104
« Reply #4 on: May 13, 2012, 07:17:37 pm »
Doesn't sound abnormal at all, what went wrong with the k24?  How do u like the t3 vs k24?
Reply #5May 14, 2012, 08:43:47 pm
silvertdvw
  • 38
« Reply #5 on: May 14, 2012, 08:43:47 pm »
I lost a fin off the turbine wheel on the k24. The two turbos are very similar can barely tell the difference, but physically the k24 has bigger outlets for the cold and hot side.
